Have you experienced the "grabby" brakes?
Discussion in 'Gen 3 Prius Main Forum' started by Pugsy, Sep 11, 2009.
  1. Yes
    114 vote(s)
    82.6%
  2. No
    24 vote(s)
    17.4%
  1. rich27517
    rich27517 New Member
    Chapel Hill, NC
    I have a III. Grabby brakes backing up, usually out of my driveway which is slightly sloped. Has happened 3-4 times in 1000 miles.
  2. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    seriously. why should i buy this car?
    grabby, squeeling, brakes
    display may burn out
    so-so visability
    what else?
  3. rich27517
    Chapel Hill, NC
    It's a great car. Very comfortable, terrific mileage, excellent quality and workmanship, etc. Grabby brakes are a small problem that I am certain Toyota will remedy. Visibility is better than my previous Camry. No rattles, very tight.
  4. Pugsy
    Pugsy New Member
    76
    The same was the case with me the time it happened. I sat in the car for a couple of minutes filling out a check so I could mail a bill before I turned it on. I went out this evening and did the same thing intentionally, to see if I could get it to happen, and it did.
    It's probably just a coincidence, but who knows?
  5. jayvee
    jayvee Member
    341
    89
    WA
    At least twice. Once backing down driveway at a slight slope (engine cold), and once backing up on a level surface (engine warm).
  6. Phil Seastrand
    Phil Seastrand Junior Member
    Roseville, CA
    I can get mine to do it fairly consistently. If I park with the car on a up-hill slope and attempt to backup first thing after starting it, it will exhibit the symptoms.
  7. dfran1
    dfran1 New Member
    89
    17
    MA
    I hope your not serious, This is a great car, most likely one of the best.
    I have 2 of them and love both!
    I fixed the cloudy/blurry AC screen
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/64855-cloudy-blurry-ac-screen-18.html
    Have I felt the grabby brakes, maybe but it is not that bad at all.
    Visibility is the same as my 05 Prius I had. (I think it is good)
    I think I have read one or two with bad displays (I hope I did not miss any).
    If anyone thinks that for one minute any other car is more reliable or problem free, go search for its forum and see all their complaints, I will guarantee more major problems. This is Toyota's flagship hybrid car, if anything major goes wrong, people will be looking elsewhere for sure!
    But like anything else, there are always things that can go bad (I would just hope it is just minimal with these cars, like it is so far).
    Good luck
    Don
  8. neggen
    neggen Junior Member
    Seattle, WA
    I have this forward lurch problem happen far too often. Every time I hit a bump in the road while slowing down I get the shooting forward sensation. Freaks me and my significant other out. My 2004 prius never did this - what changed for 2010? Any resolution?
  9. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    First, I think neggen is talking about the "other" braking issue.
    I've had the very low speed grabby problem maybe 8-10 times in 5400 miles. Usually in reverse, out of my garage after sitting overnight or a similarly lengthy period. It did occur once going forward in a parking lot where it had been parked and off during a quick grocery store stop. Can usually tell it is going to happen as the brake pedal sinks lower than normal prior to occurrence.
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    My inlaws have experienced this when backing out of their garage onto their downward sloping driveway. Has sometimes occured on flat surface backing out of parking space at work. Generally the car has sat parked for at least a few hours.
  11. codybigdog123
    codybigdog123 Got Mad and Left in a Tizzy
    239
    29
    Chicago, Il
    Because if you don't, someone else will. :rolleyes:
    Grabby breaks...squeeky breaks? I have none of those problems, but I guess some do. I've had very few cars in my lifetime that didn't have squeeky breaks at some point. Not the end of the world, if you ask me.
  12. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    The Grabby Brakes issue is one that has been under discussion for quite some time.
    Many have encountered this phenomena, while others feel it's driver induced.
    We personally have experienced this problem on about 6 occasions, however, they ALL occured relatively shortly after we purchased the car in early August of 09.
    It's just come to mind that each time the Brake issue occured, it was relatively warm weather, and the car had relatively few miles on it, under 2000.
    Now that cooler weather has arrived, or now that we have a few more miles on the car (2500), the issue has become moot.
    Is it possible that either higher mileage or cooler weather affects this situation? For the last 60 days (last 1200 miles) we have not encountered the Grabby Brakes further.
    David (aka Blind Guy)
  13. sendconroymail
    sendconroymail One Mean SOB
    256
    Speaking of strange things with breaking, acceleration, etc.... Did you hear that if you have the cruise control on and you hydro plan the car will actually speed up. I don't just mean the Prius any car will do this. Someone told me the new Sienna does not allow the cruise control to be set when the wipers are on. I have not verified that yet.
  14. codybigdog123
    239
    29
    Chicago, Il
    I guess the questions I would ask all those that have experienced the grabby break phenomena is - How severe is it? Enough force to pull your back off the seat, or is it slight? Is it dependent on break peddle force/pressure - ie, do you experience it when the breaks are just lightly depressed? Finally, has it gotten better/worse as the car gets "broken in"?
  15. Acre
    Acre New Member
    104
    Woodside, CA
    Happened to me twice in the first week while backing down a fairly steep driveway. Hasn't happened since and I've gone down that same driveway since. Both times it happened the car had been sitting for 2 hours of more before I started it.
  16. Blind Guy
    352
    194
  17. egale
    egale New Member
    NY
    Just happened to me tonight. I drove about a mile to the train to pick up my wife. Sat with the car off about 5 minutes. Started up, backing out of the space the brakes got super grabby. Once put the car into drive, the problem went away. Only have 150 miles on the car.
  18. barnabas
    barnabas Junior Member
    53
    new hampshire
    My brakes locked up repeatedly backing out of the garage, then again later in the day backing up. After driving 75 miles they were fine. I was a auto tech for ten years before I got my engineering degree. I know the difference between sensative brakes and a problem.
  19. Tideland Prius
    16,681
    Well I only get it under a certain condition and that condition is repeatable.
    I just sit in the car with my foot on the brakes for a while (say 5-10 mins?). Once I'm ready to go, if I creep out of the spot (forwards or backwards), any slight depression on the brake pedal will induce a full brake which will fling your head forward (or backwards) as the car comes to a complete stop. One way I've found to remedy this is to simply let go of the brake pedal completely then re-apply the brakes. It's repeatable. Try it.
  20. DetPrius
    545
    92
    Southeast Michigan
    Tideland, I have not been able to repeat it but I have been able to get rid of the immediate problem by completely releasing the brakes, without shifting out of "D". Have you noticed when it happens the brake pedal has sunk further down than normal?
