Having issues with P2195
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pvmtchsn, Jun 6, 2020.
  1. Frankusa94
    Frankusa94 Junior Member
    60
    16
    Ma
    That’s interesting theory…Do you think that fuel pump strainer/filter can be cleaned up a bit… instead of fuel pump replacement?
  2. ASRDogman
    ASRDogman Senior Member
    8,042
    4,075
  3. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    I don't think by the looks of the strainer it can be serviced. Maybe a parts cleaner? It's the "fabric" that gets stained and clogged up like an air filter. The fabric is not serviceable.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Black smoke, low MPG, loss of engine power are all indications that the car has a fault that results in too much fuel injected.
    Add in your P2195 code and that points to a (very likely) bad upstream Air Fuel ratio sensor. I have seen similar faults enough times over the decades.
    I would recommend:
    1) If you want to learn about how the fuel control system works, then get a capable scantool to monitor ECM engine data and diagnose the problem.
    2) If you just want to do something that will probably fix the problem and doesn't require the brainwork and legwork of diagnostics, then replace the A-F sensor with a genuine Toyota or Denso part and see what happens.
    Brian1954 likes this.
  5. Frankusa94
    60
    16
    Ma
    ****UPDATED****
    I have observed interesting ST and LT fuel trims suddenly change around 65mph. Car drives daily with ST around 0 and LT around -12. Once I take the car up to a constant 65mph on flat grade…within the next mile or 2 the trims work their way to approx… ST 20, LT -25 basically a radical change in just a 1 mile of travel. I have found that if I immediately back off the throttle, drop down 55mph… I can bring the trims back to ST 0, LT -12, -15
    If I don’t back off soon… in next mile or so… car will set p2195, and sometimes p1151, then blow black smoke and sometimes stall, drive on hv battery only…quickly requiring a visit to break down lane……ugh!!!
    I have a new denso upstream sensor arriving soon and will post update after install and testing.
    Thank you
    Frank
    V Sport Wagon, mjoo and ASRDogman like this.
  6. Frankusa94
    60
    16
    Ma
    ***SOLVED*** 2007 Prius stalls at highway speeds P2195
    Issue was solved by replacing aftermarket upstream o2 sensor with a genuine Denso o2 sensor. Aftermarket worked fine at all speeds below 65mph… once above 65mph… fuel trims would swing wildly causing a massive rich condition that often stalled engine. This cause the car to throw p2195 requiring a trip to the breakdown lane. Just goes to reinforce why certain genuine oem parts are essential for proper repair. Car has approx 50miles of driving above 65mph to prove issue is gone… fuel trims are very stable now at 65+ mph.
    Hope this info helps others.
    Thank You to All!
    Frank
    ASRDogman and Brian1954 like this.
  7. Frankusa94
    60
    16
    Ma
    I made a YouTube video describing my recent purchase of apparent fake “Genuine TOYOTA OEM” parts on the internet. upstream o2 sensor.
    … link to video…
  8. ASRDogman
    8,042
    4,075
    I forget his name, but the Toyota guy in Illinois did a video on how to tell the
    cheap chinese copy parts from the OEM parts.
    Bottom line, if you don't buy the part from Toyota, it ain't a Toyota part!
    The Prius seems to be very sensitive to non Toyota parts, especially electronic parts.
    #28 ASRDogman, Mar 3, 2025
    Frankusa94 and Brian1954 like this.
