Having traction issues, time for 17"?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Higgins909, Oct 17, 2018.
  1. Higgins909
    Higgins909 Member
    289
    71
    I need guidance on what path I should take. I'm having traction issues and am looking into tires and rims. Is it my tires, is it my car, is it the weather? I'm trying to drive without engaging ABS or ESP/TCS.
    This last week has been bad. It's been in the mid 40's to mid 50's this week with rain as well. (roughly Austin, TX) I'm not sure if it's my car or my tires are just that bad, but I'm having issues with traction. I have a 2010 Prius, level 3 Trim, 168k miles, 15" rims, 195/65-15 Douglas all seasons, rest is stock as far as I know. On certain turns (Dry and 90 out) I complain about understeer with these. Today's traction issue was when I was trying to leave my neighborhood, onto the main road. I gave it a bit of gas, not too much and the tire spun, then I got on the brakes because I knew I wasn't going to make it, which abs then goes off. I only moved about 1ft , going <1mph. I'm not sure if the panic brake feature kicked in or not. (forget the actual name of the feature) But I don't think I got hard on the brakes either.
    I've dropped my PSI down to sticker, as I was running 46/44 (tire max 51) and it seems to be better. (I think I hydroplaned a bit, on Monday with the tires in the 40's) Right now I could care less about mpg. In fact my mpg seems to be stable. But I do know my car gets better mpg in the rain for some reason.
    I don't actually know the maximum size I can fit on my stock car.
    I would like the speedo to be accurate, although at higher speeds, it seems to be 1-2mph off depending on how fast, as it is now. GPS 55, car 56.
    I'm debating between a few different things.
    1 Live with the current tires and pray I don't hydroplane and total another car.
    2 Get new tires, but stock rims. $400~
    3 Get new tires and new rims $1200~ Keep old stuff
    4 Get new tires and new rims and TPMS $1400~ Keep old stuff
    I'm wondering how much longer my car will last before something big happens and I just spent a bunch of money on tire/rims.
    My state (Texas) doesn't seem to require TPSM according to tire rack. I've been thinking about a 235/45/17 tire on a 17 x 7.5 rim. I am looking at the lower end range of rims on tire rack, $100-$150 but I want some high end all seasons. I haven't looked around too much, but these "Ultra High Performance All-Season" Michelin Pilot Sport A/S 3+ seem nice. $150~ each. Rated for 186mph... There doesn't seem to be High performance all-seasons for the stock 15" size.
    So, what do you think?
    Higgins909
    52,773
    it's your tires
  3. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Agreed. There are lots of better tires out there that would perform well on 15" rims. No need for 17" rims unless you like the look of them and a little less give in the sidewalls. You give lots of info but not how many miles on the tires.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    AND......it is highly likely that driving a bit more "conservatively" would help some too.
    Just being realistic here. I haven't had a traction issue in close to 30 years.......that wasn't caused by ice on the road or wet painted lines on the pavement.
  5. Higgins909
    Higgins909 Member
    289
    71
    They have at least 3-4K miles. Recently had to put a plug in one of them. They still have plenty of tread.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Most likely you hydroplaned because you need to drive slower on water. But check the wear on your tires’ water duct.
    If your drive way has rocks gravel that’s loose then it’s normal at times for wheels to spin at 1 mph. 3000+ lbs vehicle will do that.
  7. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    The circumference is correct, now, so your speedometer is good, Michelin defenders, an all weather tire with a 90,000 mile tread life is excellent in water, if you go to a 17" wheel with a wider tire you still need a tire that is good in water, obviously your present tires arent.
  8. Higgins909
    Higgins909 Member
    289
    71
    What about Sumitomo HTR A/S P02? They are about half the price and have a better temperature rating, but don't last as long. I noticed something about my tires. It can feel like I'm slipping, but if I hit the brakes harder, it doesn't lock up or anything. It just brakes harder.
