Having trouble identifying this part... Not a fog light
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CosbyComedy, Aug 12, 2016.
Tags:
  1. CosbyComedy
    CosbyComedy Junior Member
    46
    52
    Columbus Ohio
    Would like to upgrade on both sides but I cant find the part number on any of the diagrams online.
    Any help is greatly appreciated!
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I think that is the front turn signal. You should be able to turn them on and check yourself.
    http://www.toyota.com/t3Portal/document/om-s/OM47685U/pdf/OM47685U.pdf
    page 481 says turn signal
    On page 577 both the front and back turn signal bulbs are WY21W.
    If you are just looking for replacements amazon.com/Philips-12071B2-Light-Bulbs-Blister/dp/B00GRYFQ9I
    If you want LEDs amazon.com/JDM-ASTAR-Extremely-Chipsets-Brightest/dp/B00PGRGSH6 But be warned, LEDs will mess with how fast the flashers flash, you WILL need to make Relay/resistor changes.
    #2 JimboPalmer, Aug 12, 2016
    CosbyComedy likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  4. Umar Muslim
    Umar Muslim Junior Member
    22
    Lahore, Pakistan
    2011 Prius Alpha
    Brother its the Front/Bumper Turn Signal
  5. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    orenji likes this.
  6. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    What do you mean by "upgrade"?
    Dylan Doxey likes this.
  7. CosbyComedy
    46
    52
    Columbus Ohio
    By Upgrade I just mean a fog light or daytime running light that goes in the spot just below the turn signal. I havent found anyone still making a combo kit.
  8. Dylan Doxey
    1,389
    3,459
    92
    Perhaps you're looking for something like this ....
    I found a set of these for sale on auctions.yahoo.com (via buyee.jp) for around $48.
    30系プリウス 前期 純正タイプ フォグランプ 配線フルセット付 /【Buyee】 "Buyee" 日本の通販商品・オークションの代理入札・代理購入
  9. CosbyComedy
    46
    52
    Columbus Ohio
  10. Vman455
    540
    556
    The Middle
    Ah, I gotcha. You might look into HID and LED foglight options too.
  11. FinToy
    FinToy Active Member
    145
    141
    Finland
    I replaced my fogs with Osram LedFog system, it's a direct replacement with stock fog lights and they also include LED DRL's.
    [​IMG] [​IMG]
