Having trouble separating engine and transaxle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius_chatter, Apr 17, 2021.
  1. prius_chatter
    prius_chatter Junior Member
    Montreal
    Hello all.
    I'm parting out a 2007 Prius for fun. More or less following BodenM's excellent guide on removing the engine out the top and it has been smooth sailing up through step 6 where we separate the engine and transaxle.
    Apparently there are a total of 10 bolts holding the two together:
    • 2 19mm bolts through the bottom engine mount which anchors the engine and transaxle to the front cross member
    • 2 14mm bolts through the starter block-off plate
    • 6 more 14mm bolts on the top, rear and bottom of the engine and transaxle cases.
    I've removed all these, as well as both pieces of the passenger-side engine mount. I've got the engine suspended from a hoist and the transaxle propped up by a floor jack. According to everything I've read, the engine can be pulled off the transaxle now, with a little coercion.
    But I've been pulling and prying and pulling some more and even raising and lowering the jack and hoist and generally being progressively rougher with it, even to the point of possibly damaging the engine/transaxle. The engine just doesn't want to come off. There's a convenient spot for prying on the front of the assembly, and I can get the cases to separate a little by prying there, but they snap back together afterwards. It's like I've missed a bolt near the top, but I definitely took all the bolts out.
    So...if you've done this before...any tips? Am I missing something? Or do I just have to pull harder?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Though not gen3 specific, curious if @Ragingfit or @cnc97 might have some valuable input.
    Raytheeagle and Mendel Leisk like this.
  3. Mendel Leisk
    38,875
    I recollect @Ragingfit notes a recess on the underside seam (3rd gen) that seems made for putting in a small cold chisel, giving it a few taps.
    Also triple check there’s not one more bolt.
    #3 Mendel Leisk, Apr 18, 2021
  4. cnc97
    cnc97 Senior Member
    1,422
    1,530
    38
    Evansville, IN
    IIRC, mine separated on its own when all the bolts were out. Just make sure that you are relativity level when lifting the engine. Otherwise you’ll put it in a bind.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,529
    1,611
    NJ-USA
    How is everything for general rust and corrosion? Your description makes me wonder if there is rust built up on the transmission shaft splines, seizing it in the damper that bolts to the flywheel. If that's the case, not sure how you would get them apart.
  6. black_jmyntrn
    black_jmyntrn Senior Member
    1,331
    344
    2013 Prius Plug-in
    I wish an update or status to this was here
