Haynes Prius Repair Manual...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by klodhopper, Jan 20, 2008.
  1. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Yes, there are a number of pages devoted to diagnostic codes in sections for 2001 to 2003 and then 2004 to 2008. Not much in the way of exploded parts views.
    I received the manual pretty fast since it shipped from about 250 miles from me.
    The manual was worth it to me because there are a lot of pictures with arrows pointing to the subject matter along with good descriptions of "how to".
    All in all it is a good manual, especially for someone new to the technology.
    The premise is for someone that wants to do thier own work on the Prius but it mentions (wherever applicable) that some things are better left to a Toyota tech with a scan tool even though they tell you how to remedy the problem.:pop2:
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    That's good to hear. Just curious, any mention of the braking system and any warnings *not* to bleed the brakes without the Toyota scantool?
  3. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Chapter 9 section 6 does not mention the scantool BUT it says that whenever a part is removed from the hydraulic brake system that requires removing the air from the system (ie. bleeding), you should have "special equipment and training" and Haynes doesn't recommend the casual user doing any of the work themselves.
  4. jayman
    13,439
    641
    Winnipeg Manitoba
    Hmmm, close enough I guess.
  5. jrmgkia
    jrmgkia Wish I was cycling
    53
    Campbell, CA
    Today I noticed a new 2004-2008 Prius Repair Manual on Amazon. Unlike the Haynes manual this one only covers the 2004-2008 Prius, it costs 44 dollars, and it is pre-order right now (ships in June 2008). I have never heard of the publisher, do any of you have experience with repair manuals from "Bently Publishers?" Here is the link to Amazon: [ame="http://www.amazon.com/Toyota-Prius-Repair-Maintenance-Manual/dp/0837615534/"][​IMG]Amazon.com: Toyota Prius Repair and Maintenance... [/ame]Here is the link to the publishers site: [ame="http://www.bentleypublishers.com/prius"]Toyota Prius Repair and Maintenance Manual: 2004-2008[/ame]
    P.S. So I don't derail this thread from the Haynes Repair Manual I have created a new thread about this Bently manual: http://priuschat.com/forums/care-maintenance-troubleshooting/46082-another-prius-repair-manual.html
  6. Patrick Wong
    18,214
    6,530
    Bentley publishes official VW repair manuals for that manufacturer. In the distant past I owned a 1976 VW Dasher, and more recently a 1999 VW New Beetle. I bought the Bentley manuals for both cars, and they were really great. Much better than the typical Chilton or Haynes manual.
    So, if Bentley can do a similar job with the Prius manual, this might be an excellent alternative for the Prius owner who finds that the official Toyota repair documentation is too much: techinfo.toyota.com
  7. gerlando
    gerlando New Member
    Sammamish, WA
    +1 except I have had BMWs in the past. Bentley manuals are more in depth and clear about procedures and they have way less errors in them.
  8. Rest
    Rest Active Member
    1,210
    CA
    Of course Haynes doesn't recommend it, it is called liability. But brake bleeding is easy, especially when you use SpeedBleeders.
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Sorry, not true with the Prius. It absolutely requires the scantool.
  10. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    The Bently Manual is EXCELLENT, I got one about two months ago, and quick delivery. You seem somewhat bitter over the Prius, tell us the problems you are having.....This site and Johns are both good for "Torque Specs" As I remember the Bentley Manual was about $45.00.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    I've said this before, but All Data DIY is a great online service reference. They have all the correct procedures, including warning about the brake system and scantool brake bleed procedures, for under $20 a year subscription cost
    The Prius has very specific systems. It's of no use to have a generic manual that talks about having somebody press on the brake pedal while you open a bleed screw. Try that with a Prius and you're usually screwed
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    I'd appreciate it if you could get back to us on that
  13. Rest
    Rest Active Member
    1,210
    CA
    I looked over that info and still feel brake bleeding would be easier using SpeedBleeders. Is it apparent Toyota is just covering their butts. I have been bleeding the brakes on my own vehicles for years without any issues.
  14. efusco
    19,891
    1,196
    Nixa, MO
    You really need to do some more research and trust us a bit. It simply cannot be done without the scan tool...not butt covering, it's a necessary tool for the procedure.
  15. brcd131
    brcd131 New Member
    Brenham, TX
    So I signed up at the Toyota Techinfo site, and tried to find the manual for a 2009 Prius, but all I can find is one section at a time; and it says there are over 500 sections in the shop manual alone. And it's not in pdf, the only way I could see to save it was to print it to PDF. Am I missing something? Is there an easier way to download the entire manual, or at least a major portion of it?
    Thanks
  16. efusco
    19,891
    1,196
    Nixa, MO
    I thought it was available as PDF...but maybe they've changed it. But yea, one section at a time. I'm sure it's an effort to reduce people from downloading the entire thing and it is a PITA which is why so many of us have the Haynes manual.
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    Or, why so many of us just said Screw It and subscribed to All Data DIY. I'd rather pay under $20 a year for factory-correct information than trust a vague, wishy-washy book
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    Let us know how that works out for you
  19. brcd131
    brcd131 New Member
    Brenham, TX
    I noticed that older manuals are available as PDF. But the newer format is SVG View also by Adobe. It looks nice, but is more difficult to save.
    Thanks
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    I use Adobe Acrobat Professional 9 at my home office and at work. It easily works with Scalable Vector Graphics
