Haynes Prius Repair Manual...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by klodhopper, Jan 20, 2008.
  1. Chem_Geek
    Chem_Geek New Member
    Lapeer county, Michigan
    2002 Prius
    Yes, and as someone else posted above it's a ghastly unindexed mess. If one's starting diagnosis and repair ab initio, it's a little hard.
  2. Chem_Geek
    2002 Prius
    Err...yeah. For the price of Acrobat Pro, I could almost have the stealership do the fix...
  3. KTPhil
    KTPhil Active Member
    1,379
    Go for Bentley over Haynes. Much better info.
  4. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    For me, Adobe Acrobat Pro 9 is a legitimate business writeoff
  5. jayman
    13,439
    639
    Winnipeg Manitoba
    The best source for factory-correct service information is an online subscription to All Data DIY. Typically for under $20 a year, you have current and correct data, including TSB's
  6. butchbs1985
    butchbs1985 Taking things apart is fun!
    225
    ChicagoLand
    2013 Prius v wagon
    I have the Bently manual and haven't needed anything more besides this site.
  7. NinnJinn
    NinnJinn Member
    276
    Indiana
    Ok,
    It has been a little over three years since the last post on this thread. I was wondering if there were any updates to how good the Haynes manual was???
    I will be attempting to replace an inverter myself soon... Besides a dealership at a cost of $3300, Closest person that will even touch a 2002 prius is over 280miles a way. Would be quite an expensive tow bill.
    So lets have it folks. The good? The bad? and the ugly....
  8. usnavystgc
    3,159
    988
    Tucson, AZ
    I have had good luck w/ the Haynes manual. Its not as detailed as I would like sometimes but, it is a good basic reference. It should get you through the inverter. I have both the Haynes and the factory manual and the Haynes is easier to follow but less detailed.
