Hazy Headlights Fix with Chemical Guys Headlight Restorer
Discussion in 'Gen 2 Prius Main Forum' started by ua330, Feb 25, 2021.
  1. ua330
    ua330 Junior Member
    22
    Antelope, CA
  2. orenji
    orenji Senior Member
    5,887
    3,488
    It’s a one step product that I am using - wipe on the lens and wipe off.
  3. ua330
    ua330 Junior Member
    22
    Antelope, CA
    After watching Project Farm compare the big brands
    Its clear the winner is
    looks like a UV coat is included in the kit. I'll put this on my radar for next time
  4. pasadena_commut
    pasadena_commut Senior Member
    2,483
    740
    Southern California
    This thread motivated me to clean mine up. Method was
    1. Spritz with windex and wipe clean with paper towels until the towel is no longer dirty or yellow.
    2. Polish lightly (some generic polish, using a wet old gym sock and elbow grease). This takes off any dirt that was still tightly attached and maybe smooths out a few of the scratches. A buffer would do a better job.
    3. Rinse off with water and dry.
    4. Apply carnauba wax. Let dry. With a clean towel polish off the excess.
    5. Repeat 4.
    About 20 minutes, total.
    This resulted in completely clear headlights. They were not perfect though, because the bigger scratches and divots are still visible under the wax. However, these don't deflect the photons passing through nearly as much since most of the surface irregularities are now filled with wax, which has a refractive index very close to that of the plastic. That's just by eye. Break out a magnifying glass and one can still see the mess on the surface under the wax. The only way to really repair that would be to sand off the defects, and I just didn't want to spend that much time on it now.
    If I don't wash with detergent it should hold up for six months to a year.
    #24 pasadena_commut, Mar 9, 2021
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,021
    1,950
    NJ-USA
    I have read that the only lasting good clearcoat for headlights is what is used on the car's paint- often a catalyzed clearcoat.
    One option would be to remove and prep the headlights then have a bodyman spray them the next time he's shooting a car. (great if you have a friend in the business)
    Second would be to get a can of the stuff from a place like Eastwood. But that can is something like $50+ delivered, AND once it's activated you have to use it within a day or it will cure in the can (use it or lose it) AND the fumes from it are supposed to be really nasty so you really want the correct type of respirator and filters. This could be worth it IF you had 3 or 4 sets of headlights to do.
  6. ua330
    ua330 Junior Member
    22
    Antelope, CA
    I'm glad you were motivated to make an improvement to your headlights. I will say that the Chemical Guys stuff I used was supposed to have some type of UV protection but I an already see changes occurring to the surface of the lens. So unless you use a dedicated protectant (clear coat or some type of sealant/coating) looks like you will be redoing the job soon.
    I've looked into good clear coat options and from the videos I've seen looks like 2k clear coat is what is needed (its catalyzed as you mentioned)
    On amazon they are $23 a can https://amzn.to/3rQ60gy (amazon affiliate link)
    or I found an eBay seller - 2 cans for $36 USC Spray Max 2k High Gloss Clearcoat Aerosol (2 PACK), Free - Shipping, NEW | eBay
  7. ua330
    ua330 Junior Member
    22
    Antelope, CA
    Update: oxidation and haze are coming back.
    its been about 3 months since I used Chemical guys on my headlights (just over 1 month since I posted about it)
    I the headlights are not bad yet but I can see that the California sun is doing its thing.
    CG claims the product has UV blockers that will prevent future sun damage... well I'm not a believer :(
    For what the CG stuff is worth I would probably be better off using a metal polish like someone mentioned before and redoing it every couple months (just more cost effective)
    Final thoughts - even though I was excited for Chemical Guys headlight restorer time has proven that this is not a long term solution to hazy headlights.
    As my lights start to look worse I will be looking for a different product - Sylvania and 3M are the two that I'm looking into.
    Good luck you all
  8. alftoy
    alftoy Senior Member
    1,132
    516
    Saskatchewan, Canada
    2K clearcoat spray can
    https://www.spraymax.com/en/products/product/clear-coats-and-spot-blender/2k-clear-coat/
    USC SprayMax 2K Glamour High Gloss Aerosol Clear
    $21.95 Amazon
    #28 alftoy, Apr 11, 2021
  9. rjparker
    rjparker Tu Humilde Sirviente
    9,903
    6,105
    Texas Hill Country
    I like the Sylvania kit, not the cheapest or easiest but works. Includes an essential uv clear coat that is wiped on as the last step.
  10. ua330
    ua330 Junior Member
    22
    Antelope, CA
    Oh so the clear coat is a wipe on? Hmmm. I saw that Megs has one that is spray on - I would think that the spray would be more even than a wipe, no?
    Has anyone use both?
  11. rjparker
    9,903
    6,105
    Texas Hill Country
    The wipe on flows nicely. They give you a special lint free towel for the purpose. Sprays are not as easy with their potential for overspray and runs.
  12. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    You can put a sealant on it once a month like with Meguairs Ultimate Liquid wax . No over spraying, no removing headlight
  13. pasadena_commut
    2,483
    740
    Southern California
    Agree. The Sylvania kit wipe on method worked very well. It held up for a couple of years on my Honda Civic Hybrid, which is about as good as it gets in a very sunny climate. I was able to extend the life a bit further using the metal polish and wax trick until the car was sold because of yet another failed IMA battery. Looking closely at the lenses with a magnifying glass there were a lot of small defects visible at the end, but no yellowing. Note that the Sylvania kit went onto the headlights after those had been wet sanded with a very fine paper and then polished. So I think that the accumulated surface damage was fogging things up two years later, not so much chemical and UV reactions per se. The UV damage probably did make the surface more susceptible to damage though - broken bonds are less strong than whole bonds.
    The real long term fix is to put in new headlights. Generics can be had for $50-70 per side from RockAuto. It might be cheaper after 5 years or so to just replace them rather than to keep trying to fix them.
  14. ua330
    ua330 Junior Member
    22
    Antelope, CA
    Ok good to know - thanks for the insight guys.
    Rockauto has Halegons for $60 but HIDs (which I have) are $180! So cleaning kits for me :)
