Head bolts - reusing or replacing?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Seth the Younger, Jun 16, 2022.
  1. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Great thread.
    OP, Seth, measured, per the workshop manual procedure, and deduced the head bolts are good to re-use.
    My two-cent comment is to make sure the head and bolts threads are dry/ clean of oil before reinstalling.
    FWIW, so many bolts are torque to yield that I would have replaced, as the cost appears to be near $35.
    Good luck OP.
    If there is a failure in "x" miles, please let us all know.
  2. Mendel Leisk
    42,352
    Repair Manual recommends the head bolts be soaked with motor oil when installing.
    You do want to ensure the hole and its threads are clear.
    michaud85 likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    With all the problems just open deck design is having if I was to take this on might as well just use new bolts but I don't take this on so I don't worry about any of that personally on some of the beams engines like the 3S GTE they're called out to just be replaced I've seen people reuse them oh well.
  4. Mendel Leisk
    42,352
    Gasket Masters never seem to pay any attention to the head bolts they pull out, nor check them. Seems like they always just reuse.
    Personally (if I was ever in this situation), I’d replace them, just because I’m a worry wart.
    michaud85 and Brabus82 like this.
  5. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    Got a question for you... I was watching a mechanic on Tik Tok opening the covers on an enormous jet engine on a commercial airliner and after undoing loads of latches and flaps the main cowlings appeared to be motorized and raised up at the push of a button. So I'm wondering if the biggest jet engines typically have dedicated motors to lift those big covers, or just some gears that the mechanic attaches an auxiliary motor too?
  6. michaud85
    michaud85 Member
    75
    51
    Maine
    2018 Prius
    Posting a 1 year 1 month update after reusing the head bolts. 50k miles and no coolant leaks yet
  7. adrtho4
    adrtho4 Member
    71
    26
    Houston, TX
    I just bought new bolts for my headgasket repair. They were inexpensive and if I can avoid taking the engine apart, I'll do what it takes. haha.
  8. Tombukt2
    13,864
    2,519
    Durham NC
    I've not had any trouble re using tq to yield fasteners . Not recommended . But. Now they inexpensive enough for all.
  9. johnHRP
    johnHRP Active Member
    646
    191
    KA, DE
    Excel
    Usually mechanics use a set of gaskets and head bolts when replacing head gasket. My only experience was Nissan Altima 2.5L 2002 head gasket. It was replaced with Felpro sets. They hold up really well from 66k miles until 130k miles when I sold it. More than 6years and runs perfectly and I won't worry of using aftermarket head bolts if Toyota bolts are too expensive.
    Felpro gasket is also has ticker lips
  10. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    I reused the head bolts, and used fel-pro head gasket. Will update in 10k miles (y)
    johnHRP likes this.
  11. PriusCamper
    13,467
    5,434
    @Mendel Leisk has info on how to measure/test existing bolts. Also becuase of Gen3 headgasket problems Drew over at https://www.instagram.com/skimmilkhybrid/ is using super expensive headgasket bolts that they use in racecars to see if that will help do a better job at holding things together.
  12. Mendel Leisk
    42,352
    Yes but step one is to access the bolts. It's likely all good. Anyway, attached.
    (looking at attached, overall length is indicated, guess that's "a", but what the heck are "b" and "c"? Maybe on the next page?
    Meh, later, grandson coming over to change oil on his '07 civic.
    rjparker and PriusCamper like this.
  13. Mendel Leisk
    42,352
    ok this one better
    (also, last link in my signature is the FULL engine section)
    (on a phone turn it landscape to see signatures)
  14. Tombukt2
    13,864
    2,519
    Durham NC
    Aren't they only like $40 a set now or something? And the costly ARP equals are like 14 bux a pop or such.
  15. PriusCamper
    13,467
    5,434
    The race car ones that Drew uses to maybe ensure no more future problems are $300 a set.
  16. Tombukt2
    13,864
    2,519
    Durham NC
    I used to do a bit better . ARP used to be thee company now id think they're must be hundreds of companies
