head gasket and bent piston #1 connecting rod
Discussion in 'Gen 3 Prius Technical Discussion' started by springer222, May 16, 2021.
  1. springer222
    springer222 New Member
    san Francisco, CA
    2013 Prius v wagon
    Just completed a head gasket replacement and replacement of bent piston #1 connecting rod on my gen 3 prius V. There are lot of information out there about head gasket replacement, but nothing about replacing bent piston rod. I just wanted to post this to confirm that piston #1 rod can be replaced without removing engine from the car. Just remove the oil pan and the oil pump and bottom of piston #1 rod is visible, allowing removal of the bolts for rod cap with 10mm 12 point socket. Then piston can be pushed out using wooden rod or screw driver with paper wrapped at the end ( to avoid scratching the bearing). It turns out that 3rd gen prius shares the piston rod with Corolla (2010-), so corolla connecting rod can be purchased instead of prius connecting rod. Piston is easy to remove from the connecting rod as the floating wrist pin is secured by small spring clip which can be easily removed with small screw driver. Unfortunately, piston #2,#3, #4 are not accessible through oil pan on prius engine, so replacement of piston rods for these will require removal of engine.
    ToyXW, ETC(SS), privilege and 2 others like this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Out of curiosity, it sounds like you installed the original piston onto the new connecting rod. You didn't have any concerns that the piston may have a crack(s)? Or the wrist pin hole may be out of round?
  3. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    From what I read, Toyota says you need to head the piston/rod assembly to press out the wrist pin.
    Maybe that was from the 2010-12 model years?
  4. Mendel Leisk
    42,364
    Is there any advantage to doing this though; is the Corolla part cheaper, more readily available? If either will do, perhaps they’re actually the same part, including part number?
    Fortunately it’s cylinder one that is usually having the failures, lol.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    OR that the piston scraped the cylinder walls ?
    And are the bearings top and bottom a part of the rod assembly ?
    If not, did you change them too ??
  6. bisco
    52,878
    great info. thanks, well done!(y)
    springer222 likes this.
  7. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    Thanks for this valuable information, which I have not read on here before!
  8. privilege
    privilege Active Member
    659
    169
    Birmingham
    that's pretty cool if you to share, thanks !
  9. springer222
    san Francisco, CA
    2013 Prius v wagon
    Yes that's a good point. Luckily I examined the piston carefully, but found no cracks or any other damage. The wrist pin is also identical on prius and corolla, so I slid in the wrist pin from corolla part and prius part into original cylinder #1 head with about similar amount of effort. Thanks to gasket masters video on this topic, I was able to catch the problem before putting the head back on. Leaving the original connecting rod ( bent on both axis ) would have resulted in catestrophic failure soon afterwards. With new connecting rod in place (and without head), I was able to freely spin the crankshaft with very little effort, a vast improvement from original condition with bent connecting rod where it would stick every time as #1 piston went down. The reason I bought corolla connecting rod/piston was due to what's available on ebay - one for corolla was only $32, but one for prius was going for $65. Per toyota dealers parts online, it was clear that same connecting rod is used for both 3rd gen prius and corolla (2010-) so we can save a bit of money with used corolla part.
  10. ChapmanF
    19,042
    Are you saying they're both the same part number, and you just found an arbitrage opportunity between different eBay listings for the same part?
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I would find this to be totally believable. It's amazing how two identical things can bring in totally different prices. Merely for example, advertise an HV battery module for a 2007 Prius, a 2007 Camry or a 2007 Lexus. All the same module but ebay used to be crazy different prices.
  12. Mendel Leisk
    42,364
    Someone on a desktop could more easily check the part no’s. Just thumbing on a phone here.
    #12 Mendel Leisk, May 20, 2021
  13. PriusCamper
    13,470
    5,438
    If we had legit consumer protection laws, these types of pricing scams would be illegal... Alternatively, we need an online service that specialises in cross referencing parts and measuring and testing so you can find the most reasonable price, rather than the jacked up price depending on how expensive your car is...
    My latest interaction with this racket is the trailer wiring "kit" for Prius... Most people end up spending $60-$100 for a "kit' that's designed for their car and the adapter box I bought on my trailer wiring kit a 1/2 dozen years ago was malfunctioning and there's no way I was going to buy $5 of wires for $60 just to get the adapter box. Instead I spent $15 on this: United Pacific 90623 Trailer Light Converter - 4 To 5 Wires | eBay and it was easier to wire up than the so called kit.
    I'm grateful for Priuschat helping us figure out workarounds for all the many pricing scams that prey on the uninformed...
    DieselHammer likes this.
  14. mpswirl
    mpswirl New Member
    Arizona
    I own a shop that specializes in Toyotas. Ive down a lot of Prius head gaskets as well as complete engine rebuilds. Cylinder 1 is for sure the easiest to get too. Ive also seen the rods very slightly bent causing the piston to not move back and forth in the cylinder. Also use a straight edge and make sure the block and head are straight.
    DieselHammer and CR94 like this.
  15. DieselHammer
    DieselHammer Junior Member
    29
    Kansas
    Great thinking. Excellent share.
    Many times a manufacturer will place a different part # on the same part allowing different appplications. Regardless if the part number is the same or not between Prius and Corolla … the firmest worked. Report back as mileage climbs and keep us in the know.
  16. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    Leave the oil pan in place, and drop the entire crankcase instead. This gives you access to all four connecting rods and pistons without having to remove the engine.
  17. ChapmanF
    19,042
    I can't stop wondering about the rear main seal in a procedure like that, though.
    I mean, there isn't even a separate rear seal retainer on this engine. When you install a new rear seal, you just drive it into the round bore that's formed by the semicircular openings in the block and 'crankcase' coming together. Breaking that apart, spinning the crankshaft and now-loose seal around some for access to all the rods, then just putting the 'crankcase' back up against that old seal seems like it could be asking for trouble.
  18. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    It is certainly not ideal, but by design the seal sees more friction from the block than from the crankshaft, so it stays put while you rotate the crankshaft to get different pistons to TDC. And when the crankcase assembly is hoisted back up into place and torqued to spec, it engages the seal at the same position that it did when first installed, so there really should not be any leakage.
    I personally haven't seen any in the 36,000 miles since the last rebuild.
  19. knucklebuster
    knucklebuster New Member
    2014 Prius Plug-in
    I also had a blown headgasket on a 2014 prius plug in. I went through the headgasket replacement only to put it all back together and have the same issue. I should have realized why at top dead center, piston #1 was 1/8" lower and never reached the top top of the cylinder. After replacing the engine with a JDM, i tore the old motor apart and sure enough. Piston #1 has a bent rod. Not sure if its worth replacing the rod, but at least i know what happened. After learning how to do a head gasket and an engine replacement. Jeeze!
  20. James Analytic
    416
    63
    Michigan
    Yes from what I see and read before. I found that the pistons are more unique to the specific models, though the connecting rods are not so much. I've been wondering since might be worthwhile when at the yards to pull parts from other vehicles where the parts interchange or if when purchasing online or elsewhere to bolo for good prices.
    The connecting rod for the gen 3 (2010-2015) Prius is shown as part # 13201-39185, with previous part # 13201-09A30 and 13201-09A10. This has been replaced by part # 13201-09C10 and later revision part # 13201-39295 for the gen 4 (2016-2022) Prius. Both show a potential for interchange with the relative 1.8L engine year models Prius, Prius Prime, Prius V, Scion xD & iM, Matrix, Corolla and Corolla iM.
    Technically, appears the part #13201-39295 only interchanges with the relative Priuses (AWD-e, Prime, V, Prius) and 2020-2022 Hybrid Corolla. Guessing this is the better part to replace with when doing, though the # 13201-39185 from the other engines seems good enough and in Toyota spec. I'll try to update this or make a new post for the related pistons once I research some more.
    The prior Corolla et.al. connecting rod revision and revisions to part # 13201-29177 do not appear to interchange the same way with the Prius.
    On another Prius related interchange note and probably can be posted in the gen 2 relative section:
    I found to be a similar situation with the connecting rod assembly part #23 in the diagram part # 13201-29757 for the gen 2 (04-09) Prius. Interchanges between the gen 1 Prius, Echo, Yaris, Matrix, Scion xA & xB and Prius C of the 2000 to 2019 year respective 1.5L models. The pistons I found are unique to the specific generation of Prius however.
    I just invested in a what appears to be per the VIN an original owner 2007 engine and reported by the seller to have the "wrist pin tic" and still running good for a ~300K engine other than the noise wasn't going to be appealing to a future seller so he swapped with a newer engine before selling.
    Whether that is the lifters, connecting rod bearing on the crank or like noted and I'm thinking is, the wrist pin... I'll find out once I disassemble to rebuild concurrently with the other 05 engine I pulled out of the 05 I'm working with my girl friend on restoring that blew a hole in cylinder 1's piston. I don't want the 07 to fail like the 05 one did.
