Head gasket EGR or the 2ZR Engine 2010 prius
Discussion in 'Gen 3 Prius Technical Discussion' started by johnnychimpo, Dec 30, 2020.
  1. Mendel Leisk
    41,467
    Still, if machine shop has the head, and has the valves out for lapping...
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,159
    6,316
    Texas Hill Country
    Getting the carbon out of the passages is also important.
  3. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    Here is the piston closest to the timing chain the rest are dry. This one has moisture I'm sure it's not oil so must me coolant right?? What do you guys think?
  4. ASRDogman
    ASRDogman Senior Member
    7,598
    3,916
    All that cost money. It depends on what someone wants to pay.
    If it's an honest shop, if the valves seat well, they won't do anything to them.
  5. Mendel Leisk
    41,467
    Yeah it’s usually cylinder 1 (that one) that leaks first. One or two. And likely not coincidentally: EGR passages in the intake clog fastest at that end.
  6. Tombukt2
    Tombukt2 Senior Member
    12,996
    2,330
    Durham NC
    I just paid a guy 800 to change head gasket he would not install my FelPro PT gasket he said only OEM thats all he spoke of all day oem oem .. so i bought factory set for less than the full fel pro set .. cars back together egr cleaned out lots of carbon build up on injectors he cleaned car drove 24 miles and all of a sudden a loud clanking sound like somethings hitting in the bell housing of trans . and idle is very sloppy lopey i had to dolly the car home i was scared to run engine sounding like it did . kid came over to look started it rt up . and said it needs to be hooked up to tech stream .. car ran great even with head gasket leak. once ICE is on ran fine. Now nothing . new engine maybe . this car was bought for a women I would never have done it .. thank God I kept my Gen2 all of em heading to 400 k on both gen2 the gen 3 has 256K on it mostly driven in DC metro area for work by health nuts who hated driving .. Lawn ornament now ..
  7. Tombukt2
    12,996
    2,330
    Durham NC
    ive win 10 tablets etc how do i buy tech stream to connect to this mess of a vehicle in other words what i need buy part numbers or links . of a working setup .. So i can get the lawn ornament running properly . Toyoda wants no part of it . they have spoken .. car is clean leather well maintained .. maybe itll become the new dog house .. OY
  8. ASRDogman
    7,598
    3,916
  9. johnnychimpo
    514
    112
    Monterey
    Looking for a video walkthrough on valve seals replacement anyone have a link?
  10. ASRDogman
    7,598
    3,916
    Go to YouTube, and type that in. I'm sure there are some out there..
  11. rjparker
    10,159
    6,316
    Texas Hill Country
    So a new headgasket, it ran fine for 24 miles and then the engine bricked? No start, towed in.
    I don't think you need techstream. You probably have ordinary misfire codes any reader will pick up.
    I would be concerned it may have a broken rod and part of it is clanking the block. A compression test would tell the story if it turns over. Otherwise a borescope could visually inspect it and may be easier than compression.
    This is the one I bought for another purpose.
  12. Tombukt2
    12,996
    2,330
    Durham NC
    Still starts when gas starts its bouncing around clank clank its like its missing really bad and because of off firing something rocks around he thinks a piece of shiet mayve got caught in egr that was loosened but did not release DOH.. he says the egr valve maybe suspect Or the injectors covered in carbon that he cleaned are now dripping . if that were case once dripped fuel burns up normal run would occur and re occur at next start ? but youd run risk if causing more damage to keep restarting? I told him initia;;y if he saw anything that raised red flags STop lets get whats needed Ive nothing but time.. oh well
  13. Tombukt2
    12,996
    2,330
    Durham NC
    RJ you bought what?? no link or pic
  14. rjparker
    10,159
    6,316
    Texas Hill Country
    Sent pm
  15. Mendel Leisk
    41,467
    If you have an ad blocker try turning it off, they sometimes block Amazon links.
  16. Tombukt2
    12,996
    2,330
    Durham NC
    i just recieved a toughbook loaded w 15.30 tech stream obd connectors etc . So if anyone in or near 27243 Cmon on over and lets see what we can see.|
    ASRDogman likes this.
  17. tre4xw30
    tre4xw30 Junior Member
    37
    US
    Is that nc? I'm in nc with techstream as well. Programing keys was a breeze.
    SM-N986U1 ?
  18. Tombukt2
    12,996
    2,330
    Durham NC
    techstream gave me a bunch of missfire codes i ran compression check no 2 0 psi all other cylinders on red green line about 110 sposed to be 150.. bad news.. engine time .. Do the Jdm engines have same Egr system and sposedly theres a 2.0 litre???
  19. Mendel Leisk
    41,467
  20. johnnychimpo
    514
    112
    Monterey
    I got the car put back together it had some issue with a injector being stuck open, it threw me for a loop since the car ran fine prior to head gasket job.
    Anyway bad injector. now fixed and running. two issues still to fix
    1.the car at around 1400 to 1600 rpm the engine feels like its stuttering kind of a pulling sensation like when you go fishing and the fish kinda tugs at your line sorta like that if that makes sense no miss fire code so not sure what's going on there?.
    2.timming chain tensioner is leaking it has a new oem toyota gasket and it is very tight I made sure.
    thinking of using gasket seal is that a bad idea?
    3.going to do a down pressure test what should it be at 150 right???
