Head Gasket, or not?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by we9v, May 11, 2026.
  1. we9v
    we9v New Member
    HG questions.
    Background first:
    Long time Prius owner (14 years, 2010 w/~255k miles, most miles were from 80mi/day commute at 72-82MPH, now retired), long time lurker, rare poster. I'm in the middle of a head gasket job, my first after 255k. Uses 0.5-1qt per 10k oil change, Mobil 1 0w20. Besides DIY suspension work, rear hubs, and upstream O2 sensor, the car has been rock solid. I've not even changed plugs in 255k. Just religious 10k oil changes and several sets of tires.
    Issue started years ago, maybe once a month would have the shake at start up, gone in 2-3 seconds. Never paid no mind to it, as it was rare and didn't last long (I wasn't aware of clogged EGR valve and HG issues.) Then one day 2 months ago, it decided to start shaking all the time while my daughter was out with the car (it's her daily driver now). We had it towed home. I'm fairly handy with a wrench and YouTube videos, so I thought I would tackle whatever it is when I got home 2 months later. Well, I'm home. First thing I did was remove the plugs and check the cylinders for coolant on top of the pistons. None seen. Coolant in the tank has gone down, below the low, but not empty. All pistons looked roughly the same amount of carbon, nothing obviously washed. Put the plugs back in and decided to start it up and have a listen for myself. Engine started, and the shake didn't start until several seconds later. Shut it off. I saw a couple videos where they diagnose EGR Valve vs. HG by inserting a blocking plate/putty knife between the EGRV and tube. I did that, started, and zero issues. Decided to take it for a short half-mile drive...no issue. Came back home, shut it off, started it again a few minutes later, and about 15 seconds after the engine was running, the shake started. Shut off. Repeated test, same thing, shake about 10-20 seconds later. Got out the OBD2 and had 3 pending faults in Torque Pro: P0300, P0301, P0302. Oh, never had a check engine light ever (in the last many months, not since I had an upstream O2 fail). Swapped coil packs 1 & 2 with 3 & 4 just to make sure that wasn't it. Fired up car and OBD2, same pending faults.
    So, I'm thinking not EGR related, and head gasket related. After arming myself with lots of YT video knowledge in the order of removal, I finally just got my head off. I'm not a pro, but this head gasket doesn't seem to have an obvious blow out like I've seen in YT videos. First question, how does this gasket look to you?
    Still on block, and piston tops:
    Top:
    Bottom:
    EGR Valve had some carbon on it, but wasn't really caked up. EGR tube to intake wasn't bad either. Intake manifold EGR ports were not fully clogged (maybe 50%?). But the EGR Cooler appears to be 100% clogged, brake cleaner wouldn't drain a drop. (And again, never any check engine codes.) It's taken 2 days of oven cleaner and pressure washer to get a few of the passages passing light. Could this have been my problem and not the head gasket?
    I have Fel-Pro gasket set, new head bolts, water pump, thermostat, and finally some spark plugs.
    Is having the head checked and machined required/highly recommended? Besides flatness check and machining for that, what else is typically done/recommended?
  2. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    2z not good candidate . Mileage is wer gen3 are buried generally . But you can play all ya like .you've time now. But daughter may need to get to work reliabley. Gen2 if you can believe . Or electrify her or another gasser . From one old retired military guy in the business don't do it .. piddle around play with all ya like . Don't depend on it . 2010 is when Toyota became like all the rest look all from 10 forward . Race to bottom buddy .
  3. Mendel Leisk
    42,349
    I don’t see any obvious failure on head gasket either, though there is general “erosion” of the black zones around coolant passage holes.
    cylinder one piston looks somewhat cleaner, say compared to four. Maybe coolant incursion into cylinder just starting.
    the FelPro gasket kit is apparently one custom head gasket, and an incomplete assortment of “this’ll do” smaller gaskets. The Toyota “overhaul” gasket kit is much better option.
  4. cdherman
    cdherman Member
    68
    27
    Kansas City
    Well, the OP is already this far into it -- he's going to have to finish what he started, or sell the car literally nothing to someone who can. They will charge him at least $4000 in a shop.
    I through the felpro looks a little better, and I bought the full toyota kit for $210 or so on line and the felpro for $40. I have the toyo HG left over. Should tell it for a bit of $$ on ebay......
    I am assuming that the OP has read my recent threads about testing the EGR before re-installing. If it leaks coolant into the EGR passages, you can start over the new HG.
    As to whether it was the EGR causing the symptoms or the HG, it seems likely given your coolant loss. That argues for HG but its not proof. You could have a slow leak elsewhere too.
    BUT, you are not going to be able to rule other causes for the codes until you put it back together. Might have a bad COP on one of the plugs, but the plugs are archaic also.
    Finally, yes, take the head to a machine shop. Either have yours own rebuilt, or they may trade you for an aleady remaned one. I'd think at 260k miles, you will need new valve seals. If your lit has valve seals included, take them along.
    Good luck....
    #4 cdherman, May 16, 2026
  5. WICruiser
    WICruiser New Member
    24
    WI
    I also can not see an obvious coolant leak path on the head gasket but it doesn't take much of a pathway to create the misfire problem. My grand daughter's was similar but slightly lower miles (195k), EGR cooler virtually plugged, intake EGR passages crudy but not obviously blocked, shake on start up, misfire codes, etc.
    It sounds like you have cleaned the EGR cooler and other EGR related parts and have the parts to put it back together. I checked the head with a straight edge and decided not to have it machined (mostly out of conveinece - timing). I did not change the water pump or thermostat but installed a new head gasket (not FelPro but I agree that they are better) and reinstalled everything. Torquing the head bolts is a bit scary as I had some that were smooth and some that "snapped sound" when doing the second and third steps but all has been okay so far.
    I think the decision regarding what else to do is really depending upon how long you expect the car to remain viable. I know there are a number that have higher miles but there are a lot also retired given the age and other things that can and do happen. In my case I was tryint to minimize the up front cost while recognizing that I was not anticipating another 200k worth of miles.
  6. Tombukt2
    13,863
    2,519
    Durham NC
    That's why I don't do the HG on these cars because the return isn't there if I do a head gasket and some lower end work or valve train work etc I expect another 200,000 mi bringing me to 400,500,000 total I expect that thru 09 . After that not sooo much. It's just the nature of the beast they're all like that now about 2010-2013 for some others the crap hit the fan just observe you can see it clearly
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,108
    6,970
    Texas Hill Country
    In this case, the existing teardown and parts buy should be complemented with a rebuilt head. Its not clear if the egr block fix cleared the issue beyond the first try. If it did, a new egr valve* is needed.
    Otherwise
    My usual recommendation is to skip the hg job especially on high mile engines with any oil burning. I would suggest a replacement engine which is either a quality rebuild with effectively zero miles or a hand picked JDM used in Japan engine which would be well under 100k miles and should not burn oil, which avoids oil clogging up everything.
    Either way you could then do 5k oil changes and 50k coolant drain and fills and keep it clean.
    That is also the recommendation of dealers and independents around here that have dealt with hundreds of these engines from gen3 Prii.
    Obviously there is a price difference between the two options. Rebuilt makes sense for the really nice cars that you would like to get 3-5 more years and better resale value assuming you privately sell later. There is more work here even if you buy a HybridPit rebuilt engine since you have to swap parts from the old engine.
    The JDM replacement engine for a cost that is competitive with a good hg job (eg comparable to a hg job with a rebuilt head). It is still possible to get 3-4 years of clean operation, albeit without increased resale value down the road.
    HybridPit Gold with Revised Pistons and Rings. 1.8L HYBRID ENGINE 2ZR-FXE REBUILT MOTOR (GOLD PACKAGE)
    * Do not buy the aftermarket egr valves! These have a low quality mechanism and often stick or fail to seal well right out of the box. Revised EGR-Valve is 25620-37120. The updated Egr-valve kit 04004-58137 offers the same valve at a deep discount.
    #7 rjparker, May 17, 2026
  8. Ramjet Photo
    Ramjet Photo New Member
    Southern California
    Sorry, I couldn't find how to make my own post. I have a 2012 Prius with 243000 miles and I've already replaced the head gasket, water pump, A/C unit, & small battery. Currently, it is leaking coolant into the cylinder and I am getting misfire codes. I just cannot see spending more money on this car. I have AAA+ so I can get a 100 tow. I'm thinking of driving the car as is until I can't, or should I trade it in now for a used Prius, newer than 2017. My latest fill up resulted in only 30 MPG, city driving. Thanks in advance for your responses.
  9. rjparker
    11,108
    6,970
    Texas Hill Country
    Getting a newer car is always the best idea.
    Installing a JDM engine is often better than attempting a head gasket repair unless you are a pro and spend more than a JDM engine costs.
    Ramjet Photo likes this.
  10. Ramjet Photo
    Southern California
    I am a SPED school teacher, and my wrench skills end at barely keeping my eBike working!
  11. rjparker
    11,108
    6,970
    Texas Hill Country
    You pay a shop to install it. Its an option that can be cost effective.
