Head gasket replacement..... finally at the installation point
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mellyman666, Oct 5, 2023.
  1. Mellyman666
    Mellyman666 Member
    144
    32
    Montréal
    My EGR cooler, the two little ends on the outlet, where the stud bolts drive in, are completed corrded due to rust; like corroded to the point of being able to see through the threads lol so I'm going to take a wild guess that it needs to be changed. My question is, any expert opinions on this? Don't really feel like buying a new EGR cooler and the HG job not even working. Any way to temporarily hold it or a way to start up the car without it once done reinstallation?
    Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,150
    6,989
    Texas Hill Country
    Take it to your machine shop and ask them to tap out the threads or retap to a larger size. Maybe they have a parts cleaning vat as well to clear the internal carbon.
    If that fails you could shop eBay with the part number below. It’s an expensive stainless steel part so new it’s maybe $300 up. Used but clear is fine.
  3. Mellyman666
    Mellyman666 Member
    144
    32
    Montréal
    Yeah I went to the auto shop today and saw rethreaders- never even knew that was a thing. I will ask the machine shop, if not I was going to see if it's possible with rethreaders and new bolts. And then if all else fails and no scrap yards have any, it will have to be a new one :(
  4. rjparker
    11,150
    6,989
    Texas Hill Country
    You don’t need thread inserts, just a tap that makes threads in the hole. Maybe it can be retapped to the original threads or tapped to a slightly larger thread. Tap and die set- but you probably don’t need to buy just for this. It’s five minutes at the shop.
  5. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    I you ignore the #18, the only one to take a washer and a 10 mm socket, there are two kinds you're left with:
    1. the thick ones (14 mm socket, 51 Nm of torque, 4 short and 3 long), and
    2. the thin ones (12 mm socket, 26 Nm of torque, 18 short and 2 long)
    This is how I memorized the order:
    1. The thick, short ones go on first, and you need to memorize their locations. The holes are also larger here.
    2. Then the thin ones go in in a clockwise pattern around the periphery starting from the top right edge. Two of these (#7-8) hold the water pump to the cover and are the long ones. You have to leave out the 4 holes that hold the oil filter housing to the cover—you'll get to these later. The two that go in at the top right and top left (#5, #17) will need a line of threadlocker.
    3. #18, the unique one, is next.
    4. The thick, long ones hold the engine mounting bracket to the cover.
    5. Finally, you use the 4 remaining thin, short bolts to fasten the oil filter housing to the cover.
    ksyolsen and bdc101 like this.
  6. bdc101
    bdc101 Member
    250
    usa
    Thanks for the tips! I just got the cylinder head off mine today, gonna try to measure the flatness to see if it needs resurfacing. My brother, the Nissan master tech, told me he has never found a car this new with a blown HG that the head was actually out of spec. The machine shop in town is booked 3 weeks out too. But better safe than sorry, so I'll take it down to the machine shop tomorrow. If I don't have to wait 3 weeks then I can start reassembling next weekend.
  7. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Obviously your brother hasn't seen many Prius. :whistle:
    Doesn't he have a straightedge at the shop?
    If you clean off the matting surface, and bring it to the machine shop, they will probably
    check it for you, for free. It only takes a minute or two.
    Maybe autozone or napa has a straight edge you can check it with.
    No reason to wait 3 weeks...
  8. ASRDogman
    8,070
    4,092
    #27 ASRDogman, Oct 8, 2023
  9. bdc101
    bdc101 Member
    250
    usa
    Yes, he says he has rarely seen newer cars out of spec, even after the head gasket has blown.
