Head Gasket Replacement on Gen 3 prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by prius@noob, May 14, 2022.
  1. prius@noob
    prius@noob Junior Member
    55
    Saint Louis
    @ToyXW I wonder if chain + tensioner is the only fix here.
    Seemingly the links are lining up, the TDC and cam marks are right.
    Are there other issues I should rule out before considering replacing the chain/tensioner?
  2. Alexikor
    Alexikor Junior Member
    37
    Arizona
    Any follow-up since then?
  3. Tombukt2
    Tombukt2 Senior Member
    13,844
    2,515
    Durham NC
    These engines tolerances are very tight so there's not very much swing from good to bad chain stretch and all that but usually if your marks are lining up and your chain is maintaining its path and tightness going around the sprockets you should be okay when I was dealing with timing chains and Toyota they lasted quite a long time even the plastic guides believe it or not did quite well I guess at some point there was a change in the plastic and chains got really small and dainty to keep up with the tight tolerances and tighter everything but still I mean these things are making 150,000 mi plus
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,059
    6,928
    Texas Hill Country
    Apparently he parked it and bought another Prius. Later he tried to fix it in order to sell but found the hybrid battery bad.
