Head gasket replacement reasonable price/worth it?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lydia9790, Jan 10, 2021.
  1. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    Heavy coolant loss with white smoke, rough idles.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    At that stage the motor is very likely ruined. Mr F indicated he ended up with a bent rod.
    #42 rjparker, Apr 29, 2023
  3. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    ...which I replaced for $106, thus being able to keep the rest of the engine. :)
    Of course, I did check for head warpage and the condition of the cylinder walls before proceeding.
    whataboutbob likes this.
  4. whataboutbob
    whataboutbob Junior Member
    74
    16
    Nice, did you do the work yourself or hired another mechanic besides Gasket Masters?
  5. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    I worked on it myself—no other mechanics.
    ASRDogman likes this.
  6. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    Finally got around to measuring this yesterday during a second rebuild. With the washer in place, there is a good 10 mm between the bottom of the bolt and the bottom of the threaded hole in the block. Even without the ~3 mm washer, and even after the final stretch of the bolts, there should be at least 5 mm left below the bolt, so I do not think it bottomed out at any point.
    My guess would be that when bolted in directly to the softer aluminum seat of the head (compared to the harder steel of the washer), the same initial torque (500 kgf·cm) produced a smaller clamping force. This would explain why the gasket was scuffed around that bolt, but I'm not sure why the bolt itself sheared off.
  7. DieselHammer
    DieselHammer Junior Member
    29
    Kansas
    What mileage / time warranty did they provide? Did they honor the warranty?
  8. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    1 year warranty. They did not honor it.
  9. DieselHammer
    29
    Kansas
    Wow! That’s crazy. Now they are giving out 3 year warranties. I guess it wouldn’t matter if it were a 10 year warranty. I’m sorry you had that experience.
    Did they offer unlimited mileage?
  10. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    It failed in less than a month and in less than 700 miles IIRC, but I guess none of that matters. The warranty ended the moment I paid them.
  11. honeyflower
    honeyflower New Member
    Sacramento
    SK Prius Repair does prius head gaskets for $1,200 (2024) with 6 months warranty. No hidden fees and my prius works great now. Steve the mechanic is great. they also have a website with prices
  12. Mendel Leisk
    42,352
    $100 USD for EGR cleaning? I’m a little incredulous, his charity service??
    Same price for “brakes”?
    It is refreshing, to see round number prices.
    SK Prius Repair
    #52 Mendel Leisk, Mar 15, 2025
