Head Gasket Swap - Questions
Discussion in 'Gen 3 Prius Technical Discussion' started by andreimontreal, Apr 15, 2026.
  1. andreimontreal
    andreimontreal Active Member
    390
    118
    40
    Montreal
    I'm looking on Amayama for a gasket kit and the overhaul vs grind kit is less expensive. Doesn't make sense - apparently they're both Toyota. From what I know Amayama is all genuine parts, right? Based on other parts, they might be Daihatsu parts (still Toyota, but "cheaper") - but it's not stated there.
    Rebuild videos often have Felt Pro - are those better than OEM?
    What is the "SUBS" package supposed to offer? It looks the same as the first one.
    I read that some take the head to a machine shop for a valve job and to get the head's mating surface checked. Is this really necessary? In other videos, I saw the mechanic scrape the old gasket sealer with an olfa blade, sand with a very high grit to make sure the surface is clean and that's it.
    I'm at 237k km (147k mi). I want to do a proactive overhaul/cleaning just to make sure everything is in good shape; 2012 3rd gen. Trying to extend this car's life a few more years. So, water a pump change, spark plugs, egr cleaning etc going down Nuts N Bolt's list all is in order. I suppose that should take care of it, right?
  2. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    It's best to go with Toyota, with your vin, you know you'll get the correct parts.
    Just get the FULL head gasket kit.
    I scrap off the head, and block, with a razor blade. I just don't gouge it. Using super fine
    sand paper without pressure too hard would be okay.
    They you need a metal straight edge, one you KNOW is perfectly straight, lay it across the head
    from end to end and shine a flashlight on one side and look on the other side. You shouldn't see light
    except where the valve are in the head, obviously. But between you should NOT see light.
    You also want to place it around the head to make sure it's flat. If you see light, the head is likely warped.
    Machine shop time.
    If not, it's not warped.
    You can place the head, matting surface down, on a flat table. Then spray WD40 into each intake and exhaust
    port. Spray enough to cover each valve. Let it sit for 15-20 minutes. Then carefully lift the head. You could
    put rags in the port, then you can flip it over and check the valves carefully to see if any are leaking.
    If you see don't see any WD40 leaking through, the valve/seats are sealing correctly.
    If you see ANY fluid, then you can use valve grinding compound to seat them in.
    It's what I did with mine as I had just a little seepage on one valve. I wasn't really sure if it was leaking.
    84,700 + miles and no issues with mine.
    Or you could just take it to the machine shop and let them check everything.
  3. Mendel Leisk
    42,361
    Engine overhaul gasket kit for Toyota Prius ZVW30L-AHXEBK, 12.2011 - 11.2015 - Toyota North America Car and Auto Spare Parts - Genuine Online Car Parts Catalogue - Amayama
    ^ For reference, you're looking at this page?
    I'd take the part number from there, and then for corroboration, plug it in at Toyota USA parts:
    Genuine Toyota Parts and Accessories: Official Online Store | Autoparts.toyota.com
    enter your vehicle and year (or VIN), and check for compatibility
    That said, you're doing a head gasket replacement preemptively? I'd do the other stuff, but wait-and-see on the head gasket.
    You can check the flatness of the head (and block) with a machinists straight edge and feeler gauges. Flatness pecs are in the bottom link in my signature. (on a phone turn it landscape to see signatures)
  4. ASRDogman
    8,067
    4,089
    You've only got 147,000 miles on it? Do you do a lot of city driving? Or highway?
    If you drive mostly city driving, that might be a good mileage to do it, BEFORE it fails.
    That's what I was planing for mine. I had everything I needed, I was just planing the
    best time to do it. But it started to leak.
    If you plan the time, then there is less stress to GET IT DONE. You can take your time, and no pressure.
    Take your time and triple check everything, and you'll be fine.
  5. andreimontreal
    390
    118
    40
    Montreal
    Yes about 147k mi. More highway I would say. @Mendel Leisk and yes it's pre-emptive. But I'm not 100% sure I should do it.
    But before the headgasket, I was thinking that maybe the water pump is more worthy of an early sawp. Because I know that one can really fail and it usually leads to gasket issues and engine seizure. Thoughts?
  6. ASRDogman
    8,067
    4,089
    You could start preparing now. Get all the parts you need. Get the FULL head gasket kit. It has
    the extra gaskets you need. All the cleaning stuff, rags, etc.
    If you replace it BEFORE it fails, you likely wouldn't have to worry about a warped head.
    Don't forget to check the valves for leaks.
    You could change the coolant pump now, wouldn't hurt. You could run a bore scope into the cylinders
    and see if you can notice any damage on the head gasket.
  7. Mendel Leisk
    42,361
    Judging from water pump failures reported here, I would change it every 100k mile (160k kms). Best to change thermostat as well.
    someone recently doing this had a bolt head snap off during removal, word to the wise. Doubly so in a climate like Montreal, presumably lots of road salt.
