Head Gasket - who should repair?
Discussion in 'Gen 3 Prius Main Forum' started by PriusNeckBeard, Jun 1, 2023.
Tags:
  1. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    My 2013 179,000 miles needs head gasket repair
    Shuddered on start up, check engine light on, thorough inspection by a Prius specialist.
    Will get water pump done at the same time
    Should I get done by the Prius specialist for
    Head gasket $4,000 -- is this a reasonable price ??
    Water Pump and thermometer - $600
    or is it fine to get done by my NON-specialist mechanic?
    He's very bright and experienced, but I'm concerned that without extensive Prius repair experience, is it better to go with the Prius Specialist?
    Hx:
    2022 -- had coil1 and spark plug 1 replaced
    5/23 - shudder on start up (when gas engine kicks on)
    My regular (non-specialist) mechanic replaced coil 4 and spark plug 4
    Shudder still happening like every 3rd startup
    No check engine light, mechanic replaces fuel injector
    Intermittent shudder remains
    If I accelerate, it goes away
    One time, i let it keep shuddering for 5-10 seconds
    1 mile down the road, shudder + check engine light
    I take to Prius specialist - $350 to scope it etc -- it's the head gasket.
  2. Leadfoot J. McCoalroller
    8,289
    7,803
    Pennsylvania
    2018 Prius c
    $4k sounds awful high to me.
    A Prius head gasket job is really ordinary. The work is little different from what it would be on any other 4-cylinder FWD car on the road.
    The water pump is a little weirder, but no real mechanic is going to struggle with it.
  3. audiodave
    audiodave Active Member
    800
    272
    US
    What about the EGR? There's many discussions about this issue causing this.
  4. Mendel Leisk
    42,349
    Yes. Instead of treating symptoms, deal with the cause. See first two links in my signature; on a phone turn it landscape for signature.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    What's the status of your hybrid battery ? Still the original ??
    I think:
    It might be time to trade it in on a newer model of something.
    After you spend ~$5000 on it, you will still have a 10 year old car with high mileage.
    And if the HV battery then fails, that might be ANOTHER ~$4000.
    Have you asked about the cost of putting in a rebuilt engine ?
    Might be around the same price. If so, that would be a better option, probably.
  6. PriusNeckBeard
    376
    211
    Cincinnati
    Hey Mendel,
    good to hear from you again / how are you
    A prius specialist in my city scoped and everything, is certain it's the head gasket.
    Just to be clear...
    Are you saying -- check first two links INSTEAD of head gasket?
  7. PriusNeckBeard
    376
    211
    Cincinnati
    @Mendel Leisk
    Hey Mendel,
    Just to be clear...
  8. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    My own experience is I've been to some 7 or 8 mechanic shops and had a bad experience in every one of them. Personally the only person I trust to do mechanic work is myself. Sadly, I can't do everything these new fangled cars need to be done to them.
    JohnPrius3005 likes this.
  9. Mendel Leisk
    42,349
    No, you need to deal with head gasket first, but to avoid a repeat, get on the EGR.
  10. PriusNeckBeard
    376
    211
    Cincinnati
    Thumbs up, thumbs up.
    Thanks!
  11. PriusNeckBeard
    376
    211
    Cincinnati
    Mechanic is going to clean out the EGR when doing the head gasket (and water pump replacement).
    Thanks for the info
    Isaac Zachary likes this.
  12. PriusNeckBeard
    376
    211
    Cincinnati
    The dealership quote was $10k!
  13. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    For that 4K I could swap JDM spec engines in the car twice with money left over so I'll take my way any day JDM engine stuffed in the car with or without a low mileage transmission to go with it all said and done was less than 2K not doing anything crazy just pretty much regular straight up swap. I would never pay $4,000 to work on the week open deck design it is a problematic issue If you're going to order a new center section from Toyota etc then fine but then you're talking more than four grand now if for the four grand he's talking about getting the center section from Toyota That's the reciprocating mass having the head rebuilt etc then the 4000 is somewhat reasonable and that's doable because you're getting the reciprocating mass from Toyota ready to go then it may last about the same as it did when it was new $179,000 mi so you'll be it you know three something almost 400 still not for 4K.
  14. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    10k! Yikes! That's scrap it time and buy something else.
  15. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    If your going down head gasket replacement route any good mechanic can do it, use genuine gaskets and have the head skimmed and valves reground, new valve steam seals ect.
    Water pump is removed when doing this job so shouldn't charge extra ( except for pump) for fitting as he has to put one back on car.
    I have just had mine done in the UK.. Total was under £1000 after oil change antifreeze change ect.
    Has this guy done head work before if so it's an easy job, only thing I would do is make sure you clean up your EGR valve, EGR cooler, and manifold as its already taken off its an easy job.
    While the head is off I would be giving the pistons a good soak in somthink to free up your oil control rings, this will reduce oil consumption and better to do with head removed.
    Mine was done 3 weeks ago and I've done 4000 miles since... Happy bunny
  16. taxidriver50005
    204
    170
    GB
    Excel
    Oh should have said if you go down motor swop route how do you know your not getting a motor with a already failing gasket... Better to replace with a new modern gasket in my opinion.
    ASRDogman likes this.
  17. Tombukt2
    13,864
    2,519
    Durham NC
    In the generation 3 there has no modern gasket has been invented since this engine came out gasket technology hasn't changed since the beginning of the Gen 3 so it's not the gasket technology that I'm worried about It's the rest of the engine assembly just by its design but as long as everybody's happy carry on and keep doing what you're doing It seems that a lot of the JDM spec engines don't seem to have a lot of the problems of their exported units to certain areas Go figure I stop trying to a long time ago I've been importing Toyota engine since the early '80s and running them in my cars just because I could and wanted to but like anything else in this world I would think the stuff that was going to my own country etc would have to be top notch My name is on it and it's staying right here where I live and poop. What I send out to other places well you know .... And with the way companies are doing business today I would think stuff like this would be at an all-time high It's just the nature of the beast if you will
  18. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
  19. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    NNOOOOO!!!!!!!!!! HUGE MISTAKE!
    Never use that crap! You'll be replacing the radiator and the heater core also.
    Plus having to flush out the engine and all the hoses... Another nightmare.
    Montgomery, Mendel Leisk and CR94 like this.
  20. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Nope, the new stuff is engineered better than that. Once it's sealed, be sure to change the oil.
