Head Gasket - who should repair?
Discussion in 'Gen 3 Prius Main Forum' started by PriusNeckBeard, Jun 1, 2023.
Tags:
  1. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    A new way to clog all the tiny passages.... nope.... it's crap.
    None of that crap works. It will seal ALL the small passages....
    It's your engine, and radiator, and heater core, etc....
  2. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Yeah if you use the stuff from 20 years ago. But whatever - it's up to him.
  3. ASRDogman
    8,069
    4,092
    NONE of the head gasket sealer is good. It's ALL bad.
    It just does NOT work. It "clogges". ANY passage.
    The ONLY way to "cure" the bad head gasket is to replace it with a new one.
    And have the head check and hope it's not warped.
    Like putting thicker oil in the engine. It is NOT solving anything. It's just masking it
    and making it worse.
    Montgomery likes this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,133
    6,982
    Texas Hill Country
    The sealant goes in the coolant, not the oil. It often seals Prius early head gasket leaks for 4 to 16 weeks but will ruin the heater coil and radiator. If you use the right stuff and flush it out repeatedly after 400-500 miles. It will almost guarantee the engine will have to be replaced.
  5. suntosh
    suntosh Junior Member
    26
    Dallas
    Isn't a JDM engine replacement from a vendor who gives installation and warranty a better solution and cheaper too ?
