1. Willie Walker
    Willie Walker Junior Member
    35
    Salisbury md
    You’re right what came back is just the code 71 and like you said that points that that could be the orange cable. I hope to get to that sometime next week. Thank you
  2. Willie Walker
    35
    Salisbury md
    That was perfect when I did that with the two buttons you told me about it did kick it back to zero. Thank you so much for Sharing.
  3. Willie Walker
    35
    Salisbury md
    Hello so I checked the orange cable and it did have one ohm between each side of the plug going to the converter. But i didn’t show anything when I grounded both sides of the plug that goes to the ac condenser. What does that mean? Thanks
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,119
    6,976
    Texas Hill Country
    You measure the cable removed from the inverter converter from one end to another as shown in post 35.
  5. Willie Walker
    35
    Salisbury md
    No I un plugged from the compressor and opened up converter shield and touched the correct side of prong while connected to converter. That process matched up to Diagram. Opps I guess I messed up? It was the plug end that I tried grounding to the engine and no continuity.
