Head Lights -- Low Beam too Low (computer adj)
Discussion in 'Gen 3 Prius Main Forum' started by antoine, Jul 10, 2009.
  1. antoine
    antoine New Member
    29
    maine
    Last night was my first night experience in my new Gen III/Model II.
    The low beam setting on headlights produced a beam that was too low.
    Called dealer to request adjustment. He told me they are automatically
    set by computer. I assume he meant the on-board computer.
    He didn't think he could make an adjustments in the shop.
    IS THIS TRUE? ANY IDEAS?
  2. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    They can indeed be adjusted vertically.
    The dealer is wrong.
  3. aapoppa
    aapoppa formerly known as "Popoff"
    142
    NC Mountains
    I've got the same problem with my LED headlights ( I realize you don't have LEDs.)
    My dealer and factory rep both said headlights are not adjustable. That doesn't make any sense. There has to be a starting point, the car isn't born with the headlights perfectly aimed.
    I had a Priuschat person search TIS for "headlight adjustment for 2010 Prius" and they came up with a procedure. Ask your dealer to search TIS and see what they come up with. TIS document # RM0000011MI(or 1)O(or 0)3JX
    Let me know how it works out for you.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Halogens are not computer adjusted - they're a fixed height based on the vertical adjustment screw under the hood.
    LED headlights are auto-leveling, but have a baseline vertical adjustment. A height sensor on the rear axle connected to the headlight ECU determines what "adjustment" is needed to maintain the baseline while the lights are on under certain conditions.
    2 people like this.
