Head to Head C-MAX MPG shootout vs. Prius liftback & Prius v
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Sergiospl, Feb 25, 2013.
  1. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    [​IMG]Toyota Prius v vs. 2013 Ford C-MAX Fuel Economy Comparison Drive
    While in San Diego last month, I had a Prius v-3 and a Prius five liftback mule. I then rented a 2013 Ford C-MAX from Avis Rental at the San Diego International Airport.
    The comparison focused on the Toyota Prius v and Liftback’s fuel economy vs. the 2013 Ford C-MAX claims through 4 very exacting tests including the following:
    49,385
    wow, shocking. but pretty much what we've been hearing. ford has their work cut out for them. although, people buying cmax/fusion, etc. may be buying over toyota for reasons other than mpg's.
    massparanoia likes this.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Very interesting! I've only skimmed Wayne's post. Not sure what happened to the Prius liftback for the city test, but it's not that important.
    It would be interesting to hear if/when the EPA has finally validated that everything Ford did was correct and that they were able to duplicate Ford's result (or not).
  4. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    That is solid evidence that C-Max has lower all around fuel economy than Prius v. Bigger tires, weighs more, more HP, sorry not going to win on FE.
  5. jameskatt
    jameskatt Member
    148
    50
    Monterey, CA
    Actually, the most interesting thing about the graphs is how well the Prius V keeps up with the Prius Liftback. For 5 and fewer miles per gallon difference as the speed goes up, you can get the Prius V with much more storage room and space for passengers than the standard Prius. That is well worth the sacrifice for many people - particularly cab drivers.
    wjtracy likes this.
  6. The Dude
    The Dude Member
    197
    32
    Phoenix
    Lmao ford...noobs
    Eco-Boi likes this.
  7. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    ...fantastic data as far as the speed vs. MPG, put that data in our FAQ's!
    overall that lifts "v" in my mind the "v" MPG is quite impressive match to liftback, better than I would have plotted if I made up the data (see I think like James)
  8. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    When the c-max epa numbers came out last year(remember all the "prius v killer" headlines? :) ) i had some serious buyers remorse over my recent prius v purchase. Almost to the point of cancelling my v order and getting in line for a c-max. Sure glad I kept my v!
    I'm sure the c-max has its virtues, from what i've read(never seen one jn person) more power, quieter, more traditional cockpit layout/shifter, none of which matter to me, but I could understand the appeal to some. Even at 35mpg your still doing better than 90% of non hybrid cars on the road!
  9. mikefocke
    3,692
    1,644
    Sanford, NC
    I notice all the MPGs are "temp compensated to 70 degrees". While interesting and a great graph, I'd like to know a little more about the wizardry behind the alteration of actual MPG received and the way the results were recorded.
    ~380 miles producing 5 data points on MPG vs speed means each sample was awfully small.
    I'm not disagreeing that the results you got were probable, just wonder at the rigor of the tests.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    My anecdotal experience driving the wagon for 3 months is better than Wayne reported, but I benefit from living at a high altitude. Wayne Gerdes set up what I consider the definitive test of fuel economy for these cars.
  11. SageBrush
    11,627
    2,530
    Southwest Colorado
    Anyway, that answers that: The Ford wagon is beat handily by the Prius wagon wrt to fuel economy. Will it translate into fewer Ford hybrid sales ? That is less obvious to me, although I imagine any thoughts people who own Prius might have been having of trying a Ford hybrid the next time a car purchase comes up are likely a lot less inclined now.
  12. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    how can it translate when EPA figures that customers see say 47 MPG for Ford and much less for Prius v?
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Ford's recent hybrids can run up to 62 mph (IIRC, someone please correct me, if I'm wrong) w/the ICE off. If one looks at the EPA test schedules at Detailed Test Information, only 1 schedule even goes beyond 60 mph.
    This might give Ford quite an advantage as it doesn't need to run the ICE (which is inherently extremely inefficient) for much of the test and thus not releasing tailpipe emissions, which are what the test actually measures. I suspect a fair amount of the engine runtime to charge the batteries would be when it needs to run anyway: hard accelerations or when above 62 mph.
    I'd imagine that Wayne Gerdes' highway runs were beyond 62 mph for most of the driving...
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    Are Ford hybrid owners required to sign an NDA ?
    Perhaps you are suggesting that no one reads CR, or any of the other media publications panning Ford's fuel economy claims ?
    Just my opinion, I suspect that people who buy the Ford hybrid do so either because it is 'American' or because they want the reportedly superior suspension. If the cars average out to 40 mpg I think the fuel economy will be tolerated.
  15. SageBrush
    11,627
    2,530
    Southwest Colorado
    I can imagine drive cycles that takes advantage of the higher EV speed threshold but I doubt the EPA test is one of them because the drivers are not allowed to pulse and glide. We both know that running the traction battery down to a mandatory recharge makes for if anything worse fuel economy.
  16. spwolf
    3,156
    440
    Eastern Europe
    uh, most people dont read car magazines... i would suspect that most of them buy the car since it has far better EPA mpg. EPA tests are regulated so it would be easier to compare the vehicles.
    I suspect that Ford would be getting far worse sales if they put 5-9 MPG less on the sticker (than Prius v).
  17. wjtracy
    11,321
    3,590
    Northern VA (NoVA)
    ...we're all better off if FORD does well with hybrid sales. Probably part of our problem in Virginia is the politicians don't mind pushing Toyota around. I will certainly be open minded when we go to replace the Prius but, we will run the Prius into the ground first.
    austingreen likes this.
  18. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yep, EPA test cycles have to follow the very specific schedule (specific speed at a specific time) so pulse and glide would be a no no.
    For more info see Car and Driver: The Truth About EPA City / Highway MPG Estimates | PriusChat.
    That said, if the car were optimized in such a way that the accelerations usually resulted in a pulse w/the ICE coming on and then remaining off for most of the test cycles, that could help explain the high ratings.
  19. SageBrush
    11,627
    2,530
    Southwest Colorado
    Cwerdna,
    Now that I think about it a bit more after reading your post, I recant my earlier opinion. Most of the test decelerations would happen with the ICE off. Any idea what fraction of time that takes of the total ?
    By the way, I was most surprised by how poorly the Ford vehicles hypermile. I've guessed (incorrectly) all along that their higher EV threshold would make them the favorite of Wayne Gerdes types.
    Mostly this story sounds like a car tuned for the most prevalent speed the EPA is run at, but I thought eCVTs are less prone to inefficient gearing and thus less susceptible to gaming that aspect of the engineering.
  20. acdii
    acdii Active Member
    1,124
    131
    Dont know if this helps any. Video taken on how to get 40 MPG in a Fusion Hybrid. Cold weather, and hills, dont help.
    Feb 14, 2013 7:41am | Facebook
