head unit wire question
Discussion in 'Prius c Audio and Electronics' started by jz13prius, Mar 1, 2014.
  1. jz13prius
    jz13prius Junior Member
    28
    Ok, so i bought a line level converter so I can use the stock HU with an amp. I pulled the HU out and found that the negative wires for the rear speakers aren't present for the rear. Fronts have the positive and negative but rears have just the positive wires. What do u do to connect to the negatives of the rear speakers? Any help would be appreciated. Here are some pix. In the diagram it shows a yellow and a white as the negative for the rear speakers. Where are these si u can finish the install?
    Anyone have a wire diagram that is more detailed of all the wires going into the stock HU?
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    on the smaller connector, the black wire is right rear +
    yellow is right rear negative
    red is left rear +
    white (under the red) is left rear negative.
    valuequest, SquallLHeart and ftl like this.
  3. jz13prius
    28
    Ok thanks for the help.
  4. Legogo
    Legogo Junior Member
    45
    Azerbaijan
    is it possible to use radio ignition (remote) C/3 wire as a remote for additional sub?
  5. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    It would work- the amp would turn on any time you turn on the ignition whether the radio was on or not.
    Legogo likes this.
  6. Legogo
    45
    Azerbaijan
    perfect.just need to make the amp to turn on when HU is ON.
    I'll put an "on/off" button to the gap like additional control
    thank you for help
  7. Rondy Monnaie
    Rondy Monnaie Junior Member
    Seychelles
    2017 Aqua
    Is it possible to get similar diagrams for the rest of the oem connectors that come with the prius as the one quoted below.
  8. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    Yes. https://techinfo.toyota.com
    They have all that and more.
  9. Elektroingenieur
    2,515
    3,287
    Three Touring
    That’s true, of course, for Prius c cars built for sale in the U.S., Canada, and Mexico. As I mentioned in a previous thread, however, the Toyota Aqua is covered by a different series of manuals, and I wouldn’t assume that its wire harnesses are the same.
  10. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    I’m guilty of assuming that the website in question was a gateway to all of Toyota’s published repair manuals- are you saying that techinfo.toyota.com is only good for US/CA/MX? Is there another site for others?
  11. Elektroingenieur
    2,515
    3,287
    Three Touring
    There are also websites for Europe and Australia, listed on the “Toyota Service Information and Where To Find It” page. The site for Japan (FAINES), however, doesn’t seem to be available to the public, even for a fee.
  12. Jarrod2027rus
    Jarrod2027rus New Member
    Illinois
    Im having a problem getting and voltage out of d/4 when i start the car, i tried putting an aftermarket radio in and after that didnt work i went back to original and it didnt work a fuse was blown but i replaced it. Any ideas?
