Headgasket replaced and failed shortly after? Do anything different next time?
Discussion in 'Gen 3 Prius Main Forum' started by AmazingFacts, Nov 5, 2021.
  1. burrito
    burrito Active Member
    274
    114
    Not enough data points to come to a conclusion; just get more data! You're already in the store: Try another shelf, another partition, or another ruler/level. If you're at Home Depot, just don't try anything in the lumber section.
  2. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Allright update time. Got the head back from the shop and he shaved off in some parts 7000th to make it straight. He said it was slightly warped. By the way, make sure you go to a good machine shop who's willing to take time in explaining what they're going to do and why. I called about 7 machine shops and finally found one that's excellent. Jay's Machine Shop in Santa Clara...highly recommend him. He's a one man shop and has been doing this for 50+ years.
    Robert Holt and ASRDogman like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,144
    6,986
    Texas Hill Country
    Seven thousands of an inch out. Good thing you took it to a machine shop. Many don't. It was three times the max tolerance. So much for the straight edge and feeler gauge theory.
    Brian1954 likes this.
  4. burrito
    274
    114
    Not if you take your straight edge to the machine shop first!
    ASRDogman likes this.
  5. Mendel Leisk
    42,377
    Yeah the amount he removed was 3.5 times the spec'd max warpage:
    Conversion of how much he removed, to millimeters:
    Only thing, WAS that the variation, or just the minimum amount he could practically plane off?
    xliderider likes this.
  6. tony_2018
    tony_2018 Member
    227
    68
    oil analysis, will tell you more about engine.
    from there you'll know if the engine can live on after a headgasket replacement.
  7. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Ok all done with the head gasket replacement. Boy it was more work than anticipated, but thanks to God it's done and it's running great without any CELs!
    One tip when torquing/tightening the head bolts and the cam rack bolts is to have the torque tightening sequence nearby and count out loud as to which bolt you're on. You don't want to lose track and have to start over, or worse yet, don't want to turn the bolt twice and break it.
    Regarding the heading being machined down more than specs, it would be a good thing to let the machine shop know.
    More updates as I rack up mileage.
    If anyone needs any help in the SF bayarea, let me know. I'm happy help out.
    SFO, Robert Holt, The Critic and 4 others like this.
  8. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Glad all is working for you!
    The thing about the head, if it's machined too far, the valve and piston can meet. Which is never good.
    They are already pretty close.
    Some manufactures have thicker head gaskets just for that, and to keep the compression ratio correct.
    I am not sure if they still have those or do that anymore.
    You can use a yellow crayon to mark each bolt with a line, then another line to make a "plus" on it.
    If a third time, another line. We used that when adjust valves, you mark the one you just did.
    Then you know you haven't missed any. I always marked the last one! Even though I knew there
    weren't anymore to do.
    I'm sure you'll happy for all the hard work you did and the satisfaction of a job well done!
    #28 ASRDogman, Nov 15, 2021
    Robert Holt and xliderider like this.
  9. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Thanks for the encouraging words ASRDogman and yes I agree regarding the valves and pistons meeting.
    And great idea regarding the crayon. I'll have to use that next time!
  10. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Did one head gasket and 70k miles later still works. Did another w a Fleabay HG and it lasted 10k be crapping out. Stay far far away from Fleabay. Lots o Chinese junk and scammers.
    It's hard to imagine your motor not burning oil. I had one that did initially and after 30k of WOT it stopped burning oil. Not sure why.
    I guess u can do a HG but I won't do it again. Not worth the risk of it coming back...
  11. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Yeah, that seems like a lot. I would be concerned about timing issues since the marks definitely will not line up 100% if the head had that much material removed.
    OP, glad to hear that the repair was successful. I wish I saw this thread sooner or else I would have offered to help. I am about 40 miles north of you.
    I was working on this 2gr-fe while you were doing yours. The Prius is easy in comparison. 65673543856__445C8D4E-7CBC-40F6-9C3F-9435F6F86595.jpg
    Raytheeagle likes this.
  12. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Thanks for your offer to help TheCritic. How nice of you.
    Wow you had to pull the entire engine out to change the heads on the 2gr-fe?
  13. The Critic
    3,193
    2,333
    CA
    Yes, engine removal is required for timing cover and cylinder head removal on the 2GR. It is actually fairly easy to drop the engine out of the bottom as long as you have access to a lift. It only takes about 2 hours.
    AmazingFacts and Raytheeagle like this.
  14. Tombukt2
    Tombukt2 Senior Member
    13,877
    2,521
    Durham NC
    They don't recommend machining because that thick nice person permanent torque head gasket will take up quite a bit of the issue . Or they used to .
    SM-A715F ?
  15. Tombukt2
    13,877
    2,521
    Durham NC
    I've an old LS Starter surface plate on a stand here in old shop sposed to be flat to single tenths 1/10.000 of an inch at 75 degrees . It hasn't been certified in over 40 years but it also hasn't been moved if I remember correctly from my machine shop days these have to be certified every few years from my Pratt & Whitney days memory serves me well which it may well not
    SM-A715F ?
  16. Tombukt2
    13,877
    2,521
    Durham NC
    Velcro used to make really nice copper shims just for this application for certain overhead valve engines that this was common to happen to like the 22REC Datsun l20B etc. Not sure if they still do anymore or it's been many years
    SM-A715F ?
  17. The Critic
    3,193
    2,333
    CA
    They do not recommend machining because it may cause timing issues.
  18. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Ok update time on the headgasket work. I've put about 2000 miles on since the repair and the car is running perfectly without any issues. No burning of oil and mileage is consistently about 50 both in city and highway driving gently, although I have floored it a few times. No check engine light or rattling upon start. Engine temp is also staying within safe range as well.
    There was a scare a few weeks ago when I noticed coolant smell in the engine bay and a very slight decrease in the coolant reservoir every time i drove the car. After looking under the car, I saw coolant dripping off the catshield. I traced towards the engine and saw coolant on the rear bank of the block, near the head gasket. I thought...o'oh! Upon further investigation, I saw that I had not properly fastened the coolant hose clamp from the EGR. Thank God it was just the clamp.
    So don't forget to put back on the hose clamps!
    #38 AmazingFacts, Jan 21, 2022
  19. ASRDogman
    8,070
    4,092
    I'm happy it is working well for you!
  20. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Thanks ASR!
