HEADLAMPS SUCK!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jeremy Henry, Dec 12, 2014.
  1. Jeremy Henry
    Jeremy Henry Junior Member
    MOSES LAKE
    I have a 2010 with the non LED headlamps and they are terrible at night! I took them in to dealership they aligned them, I have tried different bulbs,HID kit, everything! I hate driving at night I can't see.... Please help!!
    Fostel likes this.
  2. frodoz737
    frodoz737 Top Wrench
    4,790
    2,553
    33
    My 2010 II has had no problems. I changed out both elements after one burned out. I have noticed, when compared to our other vehicles, the Prius and 2014 Corolla do have a sharp vertical cutout on beam distribution. You might just have to get used to your new vehicle's "charactor".
  3. alekska
    alekska Active Member
    435
    138
    Atl
    Is it any better in any other cars you driven recently? If not, I suggest a visit to eye specialist may be due. My eyes got much worse after I hit 40. If it's the car, then H11 to H9 conversion may help. It was mentioned on priuschat, or you can just google it. I like the results very much.
    HID conversions often give you high temperature light, over 4500 K which is bad for color perception, rain and fog.
    Alex
    #3 alekska, Dec 12, 2014
  4. fuzzy1
    10,687
    My 2010-II came with the best OEM headlights I'd ever had, though I should admit to not having purchased any cars from 1997 until then.
    The light patterns on my 2012 Prius and 2014 Forester are essentially the same.
    Cataract surgery? I'm already on track to needing that at a younger than average age. There are also other age related vision changes that make night driving less pleasant.
    #4 fuzzy1, Dec 12, 2014
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    They are actually not bad compared to many modern cars under $30k. The Volt projectors are actually worse.
    I don't think anyone means any disrespect but maybe you do have a vision issue that needs to be addressed. Good bulbs or a quality HID kit should be more than adequate for night driving. Sure they are not Lexus or Acura quailty levels but adequate. :)
  6. fuzzy1
    10,687
    I should have added:
    Have you obtained a second opinion on this? Or can you shine the lights against a wall and give us a picture? You wouldn't be the first to have a car come with improper aim and have a shop claim they are good.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Mine were aimed way too low (perhaps factory aimed when fully loaded?) so I adjusted them up and they are fine now.
  8. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    In my opinion the headlights are actually pretty good. Now that I have an HID kit in they are even better. I think they need to be aligned again.
  9. Jeremy Henry
    MOSES LAKE
    Is their a HID kit some one would recommend? I had a kit on my 2010 and it only lasted 6 months. I paid $120 for the kit!
    And yes i have 20/20 eyesight:)
    F8L likes this.
  10. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    retrofitsource
  11. subjective
    subjective Member
    203
    30
    This T-SB-0204-12 was performed on our 2011 Gen 3 for low beam poor lighting and blowing LB bulbs. I had problems since day 2 of ownership. There is an electrical wiring flaw in the light circuits. Please take a look at this T-SB and you will see what I am pointing you to. Unless you are having a problem and bring this T-SB to their attention the dealer service dept. do not address it or do the wiring modification repairs.
    F8L likes this.
  12. Jeremy Henry
    MOSES LAKE
    THANKS EVERYONE!!:)
  13. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    I get flashed all the time in my 2010, with non LED lamps. Granted, I am running mid-grade lamps (not the most expensive, but not the cheapest).
    Sylvania silverstar, I believe.
    anyway, folks think i have my brights on when i just have my low-beams on!
    they're bright as can be!
    Jeremy Henry likes this.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If they are aimed correctly you shouldn't be getting flashed. I've never been flashed even with HIDs installed. :)
    Burna J and fuzzy1 like this.
  15. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Got my HID kit from KBcarstuff.com. Great service!
  16. Southbound
    Southbound Member
    91
    29
    Palos Heights, Il
    Couldn't agree more!
  17. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    At the age of 60-plus, I avoid driving at night -- a big inconvenience this time of year -- unless the route is familiar to me. But I do not know if it is the Prius's lights. Should I change the lights, and to what?
  18. GregP507
    GregP507 Senior Member
    3,002
    481
    Get your eyes checked.
  19. Jeremy Henry
    MOSES LAKE
    :ROFLMAO:
  20. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    I am 77 and had that problem, installed Xenon Supply HID's on our 2010's and they are great !! Been a year now and all running well, and am perfectly comfortable now with night driving....
