Headlight bulb for 2020 prius
Discussion in 'Gen 4 Prius Accessories and Modifications' started by dschulman, Aug 12, 2020.
  1. dschulman
    dschulman Junior Member
    What headlight bulb does 2020 prius use?
  2. Tideland Prius
    16,611
    LED cluster. Non-user replaceable.
    alanclarkeau likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Many cars today don't have "bulbs".
    I've read that they're over $1000 each - but will likely last 3 times the life of your car.
    Tideland Prius likes this.
  4. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    ...and bright as hell. Every other night, someone flashes me, thinking I have my brights on.
    Then I flash them back. Almost wish I could downgrade them, because I know how annoying it is.
    priusrust likes this.
  5. alanclarkeau
    7,045
    7,593
    Never had a problem with mine - maybe yours need adjusting. Has it been like that since new? But then, we drive on the other side of the road.
  6. Dngrsone
    189
    Which side you drive on shouldn't make a difference. I bought mine used with only 16K miles, but I suppose it's possible they could use a tweak. I'll have to look into that.
  7. priusrust
    priusrust Member
    219
    82
    MA
    I have same issue...harsh white light blinds cars and they flash me high beams
  8. sylvaing
    sylvaing Senior Member
    1,210
    514
    Don't forget the lights are very bright below the cutoff height. When climbing, those on top of the hill/crest will be right in that very bright region. Also, if the road is bumpy, you'll appear as if you're flashing them yourself.
