Headlight Bulb Replacement Trouble
Discussion in 'Gen 2 Prius Technical Discussion' started by runninmandan, Jan 4, 2017.
  1. runninmandan
    runninmandan New Member
    Bethlehem, PA
    I need to replace the driver's-side headlight bulb and have started to do so. I think I fully understand the process. So far I have removed the plug and the boot. I'm ready to take out the bulb but I realized that I don't know where the plug is that I just removed from the bulb. Evidently it dropped down somewhere and I don't know how to retrieve it.
    Does anyone have an idea of how I might find this thing? I don't know where the wires go but I suspect that might be a feasible approach. Of course the space is tight and visibility is limited. I'm considering using a wire hanger hook to gently tug on whatever wires I can see down there, hoping that I pull the right one up. But maybe there's an easier way?
  2. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    If fishing for the wire fails, it's not that big of a job to remove the entire assembly.
