Headlight bulb
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by PixelKing, Sep 17, 2022.
  1. PixelKing
    PixelKing Junior Member
    Dunedin, FL
    Is there a trick to reach the left headlight bulb to change it? Do I have to remove anything first? I got it in, but it’s not aimed straight- it points to the right.. 2012 Prius v By left I mean by standing in front and looking in the engine compartment
  2. ChapmanF
    15,614
    So, the US passenger-side headlight, the one on the right side of the car?
    I think I've been known to move the air snorkel, just to reach that a little more comfortably. That's in a Gen 3 liftback....
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    I would think its not in there flat. The cable is almost too short. I install the bulb first and then snap on the cable.
    #3 rjparker, Sep 17, 2022
    jzchen and Air_Boss like this.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Yes, move the air intake hose out of the way first.
    Don't operate the bulb while it is mounted off angle or you risk melting the headlight housing.
    jzchen likes this.
  5. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    In general, when bulb cables have connectors to bulb housings, always separate and seat the separate bulb in its housing first, then snap the cable in place on the housing.
