Headlight bulbs burned out on a regular basis
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Michael Daley, Jul 10, 2026.
  1. Michael Daley
    Michael Daley New Member
    Harrisburg, PA
    I had a 2011 Toyota Prius and a 2013 Toyota Prius.
    The headlight bulbs burned out on a regular basis.
    I know there was some sort of recall or enhanced warranty.
    I did what they told me to do regarding the fix. However, the headlight bulbs still burned out after I had the enhancement done.
    Is there a way to get reimbursed for headlight bulbs that continued to burn out or put in any type of claim?
    Even though I have since traded in both of these cars, I kept the invoices and payment slips also in the event that there would be a way to put in further claims on this issue.
    It looks like the original recall or enhanced warranty and reimbursement of bulbs was sometime around 2017 or 2018 which I was reimbursed for up to that point.
    I have subsequent invoices from 2018-2022.
    Any info would be great.
    Thanks for any help in advance.
    Luckily my 2022 Prius does not have this issue as that model has LED lights
    thanks,
    Michael Daley
    52,895
    this was all I could find. you could try calling toyota customer service. how much money are we talking?
    douglasjre likes this.
  3. Michael Daley
    Harrisburg, PA
    Nothing there. It did not post.
  4. CR94
    CR94 Senior Member
    2,839
    1,245
    Northwestern S.C.
    What bulbs were you using? The extra-cost, extra-bright halogen bulbs offered by some brands shouldn't be expected to last nearly as long as standard bulbs.
    douglasjre and BiomedO1 like this.
  5. Michael Daley
    Harrisburg, PA
    They were halogen bulbs that were per the owners manual.
  6. BiomedO1
    BiomedO1 Senior Member
    4,639
    2,434
    Left Coast
    Ditto if your touching the bulb surfaces while installing. Contaminates on the bulb surface will cause it to rupture and fail. I've had more issues with halogen sockets than actual burned out bulbs. I finally switched to ceramic sockets and my problem went away. I worked swing and grave-yard shifts, at the time, so my headlamps were ALWAYS ON.
    Good Luck trying to collect on a 2018 TSB..... IMHO; Life is too short to be petty - move on......
    #6 BiomedO1, Jul 11, 2026
    douglasjre and CR94 like this.
  7. bisco
    52,895
  8. Michael Daley
    Harrisburg, PA
    As per instructions for changing the bulb, I wore gloves so to not make contact with my skin.
  9. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
  10. Alexikor
    Alexikor Junior Member
    38
    Arizona
    hopefully you replaced your lights. i had replaced my low-beams and parking lights a couple months ago. i used the oem bulbs for both. the oem manufacturer for the low-beams is philips, and for the parking lights, it's toshiba. only a couple dollars more than what's on the shelves at autozone
