headlight/foglights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Bigleftyinaz, Jul 12, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    For the price, the relay is good insurance to protect your wiring and eliminate ignition issues, especially with the cheap Chinese ballasts which have a much higher ignition voltage spike than the higher end ballasts.
  2. vidoprof
    vidoprof New Member
    136
    Tampa, FL
    Ok.. So I need fog lights and was thinking of switching out the lights in my headlights to HIDs. Should I then switch out the OEM fog light bulbs etc to HIDs as well?
    Do you have a contact for Matt at TRS?
    Thanks
    Ryan
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Here is the number for TRS: 614.653.3451
    As for the foglights, it depends on what you use the lights for. If you regularly drive in heavy fog then I would say no. Keep using halogen bulbs. HIDs are not good for fog. If you just want them brighter and more white then and HID works fine. Just keep in mind that the beam pattern is very diffused and not focused so the extra brightness might blind other drivers. Some people don't care about other drivers but I bet they will care when someone is blinded and crashes into them. lol
  4. Bigleftyinaz
    Bigleftyinaz Junior Member
    76
    San Antonio, TX
    If we choose to stick with halogen bulbs and don't drive much in fog,which would be the better choice
    PIAA
    Nite tech
    Extreme white
    Or plasma yellow
    Or do we just stick with silver stars?
    Or another choice?
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I've always preferred PIAA over the Silverstars. For fog go yellow not white.
  6. Bigleftyinaz
    76
    San Antonio, TX
    Which bulb do you think would be best?
    The nite tech or extreme white?
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I can't answer for you. I have never used anything but the extreme white bulbs and I only used the whitish bulbs. I have never used yellow bulbs so I don't know which you should go with. Sorry mate. Maybe you can call PIAA and see what they say. I just know the bulbs are generally very high quality.
  8. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Nite tech = 3600K
    Extreme white = 4000K
    Do you want less white light or whiter light?
  9. Bigleftyinaz
    76
    San Antonio, TX
    I just want the best one.i drive a ton at night on dark roads. Which ever one that would provide the best lighting,I'd take. Heck I'm even thinking of adding auxiliary driving lights instead.
  10. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I recommend Nokya hyper yellow Stage 1 bulbs. 2500k color. Very yellow and practical. I've had these for over a year with no issues.
