Headlight Fuses on 2014 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by markjuggles, Feb 2, 2020.
Tags:
  1. markjuggles
    markjuggles New Member
    Wheaton, IL
    My left low beam is out. I replaced the headlight but saw that the filament was intact on the original. It still doesn't light. The voltage is close to zero and the filament ohms are close to zero too.
    So I went looking for fuses and found the "H-LP LH LO" fuse on the engine compartment fuse diagram. The only problem is that there is no fuse socket at that position and no fuse socket for "H-LP RH LO" right next to it. These are supposed to be 15 Amp fuses. There were no other pairs of 15 Amp fuses in the box.
    The next step was to check the passenger compartment fuse box but it did not seem to have the missing fuses either.
    Where are "H-LP LH LO" and "H-LP RH LO" located in the 2014 Prius? I see a reference to the #1 Integration Relay. Where is that? Is it a likely suspect too?
    Thank you,
    Mark
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    They aren’t; those markings are probably for another model that uses a similar fuse box.
    Power for the low beam headlights on both sides is supplied via the P/I 2 fuse (40 A) and the No. 1 integration relay, which is part of the engine room relay block. In parts catalog Figure 84-01, Switch & Relay & Computer, it’s shown with part name code 82641, part number 82641-47090. It’s definitely among the suspects, since it’s the first place the power takes a different path for the left and right sides.
    The Repair Manual and the Electrical Wiring Diagram (more info) both show the headlight circuits.
  3. Its34below
    Its34below Junior Member
    Roanoke VA
    Where do the highbeam bulbs get their power from. Thanks.
  4. ChapmanF
    19,055
    The DIM relay in a car without DRLs, the DRL "relay" in a car with them.
    Through the H-LP HI MAIN, then H-LP RH HI and H-LP LH HI fuses.
  5. SarahT1982
    SarahT1982 New Member
    Oakland, California
    2014 Prius Plug-in
    Hello, trying to find some information, I'm very new to learning about my Prius. Both my headlight low beams are out. High beams and all other lights work, brand new bulbs. I was looking in the fuse box under the hood, the ones in the diagram that I see marked H-LP LH LO, H-LP RH LO and relay H-LP are what I would think I need to check, but they are not in the actual fuse box. The headlights were working fine before and I haven't messed with the fuse box ever.
  6. funktuna
    funktuna Junior Member
    2014 Prius Plug-in
    Did you ever find a solution? I have the same problem after replacing my HID replacements since one burned out. I tested one at first and it worked but after installing second one neither worked. I may have messed up the polarity since the ballast plug into the headlight socket can go in 2 different ways
  7. Sam96
    Sam96 New Member
    Te kowahi
    Hey, my 2015 Toyota Prius's left headlight goes out after a second. I've changed three bulbs, and it's still doing it. I have no idea what the issue is or where the relay is located. It's only the left low beam headlight.
  8. ChapmanF
    19,055
    The no. 1 integration relay is the long white thing in the fuse box. Elektroingenieur described it in post #2 above.
