Headlight Help, center ring replacment
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by guycalleddave, May 19, 2021.
  1. guycalleddave
    guycalleddave Junior Member
    34
    grand rapids, mi
    I let an oil shop replace my headlight and they put it incorrectly and melted the plastic which the bulb clips to.
    I've searched high and low for a replacement part but can't find anything but a full assembly replacement, anyone have any ideas? It's the center light brown circle in this pic.
    I called the parts department at my local dealer and they said they don't sell it individually, but that seems odd.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    (n)
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,040
    6,920
    Texas Hill Country
    Best bet would be a junkyard, ideally from a damaged headlight for the best price.
  4. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    That would be the shops problem, they damaged it, let them fix it, at their expense.
    Then never go back to them. WHY would they need to heat/melt anything???
  5. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    the bulb and or assembly wasn’t seated correctly which caused the melt.
    guycalleddave likes this.
  7. rjparker
    11,040
    6,920
    Texas Hill Country
    Could be the use of a high powered led.
  8. guycalleddave
    34
    grand rapids, mi
    the reality is i didn't notice until the bulb went out a year later, said **** and looked for a replacement.
    didn't find anything at the time and lived with it
    now that the driver's side is out, i'm looking to see if I can also fix that issue now.
    so i'm just going to have to eat the cost unfortunetly.
    I'm just astounded that this isn't a readily available part, as it just sits inside the rubber gasket (which is a replaceable part).
    I found an old full used headlight assembly for 75 bucks on ebay, but I was just hoping it'd be a cheaper fix.
  9. rjparker
    11,040
    6,920
    Texas Hill Country
    The bulbs do burn out. Is it halogen or hid?
  10. guycalleddave
    34
    grand rapids, mi
    halogen. oh i know they burn out. The melted one is still operational, but it can't be pointed straight so it's good enough to not get a ticket for no headlight but really doesn't illuminate a large perimeter around the car. My "good" light just went out this week, so while I'm replacing them I'm going to fix it. I'm wondering if I can use a heat proof glue to just keep it upright? I'll probably just order the 75 buck part and be done with it.
  11. guycalleddave
    34
    grand rapids, mi
    you can see the light coming troung.
  12. rjparker
    11,040
    6,920
    Texas Hill Country
    It sort of looks like the bulb is not in there correctly. When installing a bulb, remove the cable, properly rotate the bulb in and then snap the cable on. Its a precise and tight fit. I don't think glue is a good idea. Most won't hold and an epoxy means you will never change that bulb again.
  13. guycalleddave
    34
    grand rapids, mi
    it's melted enough where it won't lock
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    waiting for the pruschat safety committee to reply to that.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    have you cleaned the egr circuit yet?
  16. guycalleddave
    34
    grand rapids, mi
    lol no, had kids, all my free time seems to have vanished.
  17. ASRDogman
    8,052
    4,083
    Well, the shop didn't install it correctly, they are still responsible.
    LED's are not supposed to get hot. And they don't draw much power. That is why everything is
    moving toward them. So HOW can it melt anything???
  18. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_O
  19. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Unfortunately, the only solution is to change the entire headlight assembly.
    Lesson learned, always check that the headlight bulbs are properly seated after changing them. It's as easy as checking the beam pattern against a wall or holding a piece of paper about a foot or two in front of the headlight. A crooked bulb will have a terrible beam pattern.
  20. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
