Headlight High Beam Question
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Nov 15, 2022.
  1. stevepea
    stevepea Senior Member
    535
    581
    Edit: Thanks for your answers, that did it!
    I'm going to have to try to find my owners manual but maybe someone can answer this.
    For some reason I CANNOT keep the high beams on. Is there a reason for this?
    At night I turn on the lights. For temporary high beams I can horizontally push the stick towards the driver and high beams will come on (temporarily), but in the direction towards the driver it doesn't "lock" in place, it's just for a short high beam, and as soon as one lets go the light control stick goes back to the center position. This is all normal.
    However, if I try to push the light control stick horizontally the other direction (away from the driver), it will lock in place -- but with NO HIGH BEAMS (NO difference at all between that position and when the stick is in the center position).
    This is for the 2017 "Plus" (basic) trim, so it might be different from the higher trims, but I'm just wondering if something is wrong or not. More than once I've been driving late at night in rural areas where I wanted the high beams but moving the stick from center position to away-from-driver position makes no difference. Only moving it towards the driver (which is only temporary, as it doesn't stay in that position when you let go) does the high beams. But it's dangerous to drive with one hand having to hold the light stick towards you constantly while driving if you need high beams.
    Am I missing something here? There's no difference between the light stick being in the "center" position and the "away from driver" position!
    #1 stevepea, Nov 15, 2022
  2. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    The forward light control position is for Auto for the High beams. You have to make sure the rotary selector is on Auto on the light control stalk.
    stevepea likes this.
  3. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Auto is enabled with a button left of the steering column and down low along with a host of other buttons. Make sure that is turned off. There should be a indicator on the Multi Information Display telling you whether it's enabled or not.
  4. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    Do you have auto high beams? There is a slight delay between switching them on with the stalk and them deciding there isn't oncoming traffic or tail lights ahead. On the left side where the dash dimming switch is should be a auto high beams button. You can turn it off and your headlight stalk will act normally
  5. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Two different things. Auto on the rotary light selector on the stalk is both automatic-headlights-on or off and daytime running lights.
    Auto high beams push button down near your left knee is the automatic high & low beams that is probably causing Steve's concerns.
    drash and stevepea like this.
  6. stevepea
    535
    581
    Thanks! It was that "Auto" button by the left knee. Completely forgot about the thing. Must have hit it by accident while fumbling for the charge timer button or gas tank open button at some point
