Headlight issue
Discussion in 'Gen 2 Prius Technical Discussion' started by WhoDey78, Dec 6, 2019.
  1. WhoDey78
    WhoDey78 New Member
    Bloomington, Indiana
    I have a 2008 Prius with HID headlight bulbs. I just replaced them recently, and the passenger bulb has already failed. I just received the new bulb, and as usual, took care to not touch the glass and installed the new bulb. The bulbs still did not illuminate. I tested the connection that snaps onto the back of the bulb And had proper voltage. Does anyone have any idea what could be wrong?
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Try swapping both bulbs onto the other working side. Then you will know if all three (3) bulbs are good or not
  3. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    Your ballast on that side needs to be replaced??? Note, that if your ballast is defective, it can damage a brand new bulb such that you need to replace that also.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    Make and model of the new bulb? Purchased from?
  5. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    I'm curious how this turned out. I need to replace my '07 Touring headlight bulbs and trying to avoid exorbitant charge.
