Headlight Issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rest, Sep 27, 2010.
  1. Rest
    Rest Active Member
    1,210
    53
    CA
    Every now and then one of the HID headlights goes out on our 2006 Prius, seems to be a random event not favoring either headlight. Shutting the headlights off, then turning them back on again corrects the issue. The problem with using this fix is that it isn't good for the HID bulb. Anyone have a better solution?
  2. Patrick Wong
    18,199
    6,464
    Replace the two HID bulbs.
  3. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    Known issues. Like patrick said, replace bulbs. LOTS of threads on how to do it yourself and what to buy.
  4. Salz62
    Salz62 Junior Member
    Houston, TX
    It's the ballasts. I did some digging before I found the right answer. Change the ballast and the problem should be fixed.
