Headlight/LED for 2008
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Marc Berman, Aug 23, 2019.
Tags:
  1. Marc Berman
    Marc Berman New Member
    Sacramento
    Anyone know where I can get aftermarket headlights with LED'S that fit so that the rear cap doesn't have to be removed, which destroys water/moisture seal?
  2. caravan2429
    caravan2429 Junior Member
    64
    Sandy, UT
    The bulb holding can be detached from the bulb, so you need to install the holding inside headlight housing first, and then put the seal cover on. The last thing is put your LED bulb into seal hole and lock the bulb.
