Headlight on reminder
Discussion in 'Gen 3 Prius Main Forum' started by CWM, Sep 13, 2018.
  1. CWM
    CWM Junior Member
    CA
    Every car I've ever owned, that I can remember, had automatic dinger/chimes if the door was opened with headlights on. I'm very surprised, with all the other bells and whistles on this car, that there is no dinger for lights on reminder. I don't see this addressed anywhere.
  2. fuzzy1
    10,723
    I've had this chime only on cars lacking auto-off lights. Both my Prii, like both my Subarus (1997 to present), have / had auto-off lights, so don't / didn't need this chime.
    Your 2010-II is the same year and trim as my first Prius. It has auto-off, customizable for 0-30-60-90 seconds.
    (FWIW, I didn't own or drive a car with the reminder chime until 1986.)
    #2 fuzzy1, Sep 13, 2018
  3. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    i do have a large magellan gps hooked up to my 2015 prius because i like it better than the built in. anyway, it does remind me every morning to turn on my lights
  4. Mendel Leisk
    42,384
    I've got the auto-off headlights, but don't like them, prefer manually turning them on/off. For example, I often like to run with the headlights on in overcast daylight hours. So SOL I guess. (n)
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    "Bells and whisles" are the higher trim models. Higher trims have programmable headlights to turn off automatically, or after 30, 60, 90 seconds. As Raytheeagle would say, club up to higher trim.
  6. fuzzy1
    10,723
    But if you forget to turn them off, the auto-off serves as a backup to prevent battery drain, so no harm done. Thus, no need for a reminder chime.
    In this case, 'higher trims' is really all trims.
    Grit likes this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thanks for the correction, I should have went to the manual on that one.
  8. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Simple.
    Just walk in front of the car and look.
    #8 Starship16, Sep 13, 2018
  9. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Your Prius does one better: when you open the door, the lights turn off (or start the timer to turn them off). No need for a chime.
    Toyota vehicles have had this feature (sans the timer) since the 80s.
