Headlight problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AlphaTeam, Jul 5, 2007.
  1. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    Wow, I'm glad to know my problem isn't unique! My 2004 has 254,000 miles, and my driver side light has been going off occasionally for about 6 months now. Passenger side is fine, but it got replaced after a deer decided to make a big dent in my car back in 2011. :) I'm going to get a new bulb online and see if that takes care of the problem.
  2. FredPrius
    FredPrius New Member
    Yorktown
    I have a 08 Prius. In January, I replaced both bulbs (purchased Phillips from Amazon about $100 for both). In February, passenger bulb when bad and Amazon replaced the bulb at no coast. This week (March 18), the passenger bulb when bad again and stopped working. Before, I do anything else, I would like your feedback. Do you think is the ballast or the intermittent issue? Should I do anything else before attempting to replace the passenger bulb? Your assistance is greatly appreciated. Thank you.
  3. KAR IDEA
    KAR IDEA Member
    465
    Lake Peekskill, NY USA
    Three Touring
    Given how often this is happening, I would begin to suspect the wiring. Make sure everything is seated correctly (connections tight), and keep those bulbs because they may not be the problem.
  4. RobH
    RobH Senior Member
    2,374
    987
    70
    Sunnyvale, California
    Wear gloves when handling HID bulbs. The slightest bit of oil on the glass from your hands will cause early failure.
  5. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    my 08 has the same problem so Im going to try to convert it to halogens with parts from the junk yard... yes its a set backwards but at least it will work, be safe and no more warning from the police about defective equipment
  6. Ron Bone
    Ron Bone Junior Member
    Kansas
    I have a 2005 and it does the same thing, but only during cool weather, like 45 or lower
  7. RobertK
    RobertK Member
    128
    40
    Norfolk, VA
    If the car has HID headlamps, you have a HID bulb that is going bad. Replace the bulb. You should probably replace both of them since the other bulb is probably at its end of life as well.
    The reason that it doesn't matter if the bulb is on high or low beam is that the bulb doesn't change in either position. The high/low beam is created by a moving shutter in the headlight assembly that directs the light output.
  8. RobH
    RobH Senior Member
    2,374
    987
    70
    This is the failure mode of HID bulbs. Small chance that it could be the ballast, but try a new bulb first.
