Headlight Problems
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jared, Mar 14, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Strange that they both went out at the same time.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,755
    1,783
    Bay Area
    you need small hands to get into that passenger side headlight bulb like in this video haha... glad nothing serious happened though.
  3. mediahound
    903
    155
    On my '13 there is definitely more access on the passenger side. I guess they reworked it on more recent Priuses.
  4. Magnus
    Magnus Junior Member
    23
    West Coast
    I found out the hard way the best way to change the passenger side low beam on a 2011 Prius. The area is like a little torture chamber for your hands, I'm a girl, but I don't have small hands. Taking the bulb assembly out isn't hard, but putting it back in is. I took out the bulb assembly with the harness attached, but after trying once to put it back in and failing with it attached, I watched a Youtube video where you disconnect the harness when putting the bulb back in and put the bulb in without it, after a couple of tries it went in and worked perfectly. The first time it wasn't seated properly and I thought I'd bought a dimmer bulb. The harness is very easy to connect once the bulb is seated. I guess if I had to do it again, I'd wrap up my hands with gauze or something to keep from being bruised.
