Headlight projector retrofit - HIDs to the max!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by F8L, Apr 29, 2011.
  1. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Those would look good with the shiny internal plastic painted to match your car or black.:cool:
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I've thought about that but I'm sure I'd screw it up. Besides, the high polished wheels kinda match the headlights. :D
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Do they have picture of the Phillips on the top and Mori on the bottom? I don't doubt that the Phillips is better but the picture is biased in favor of the Phillips making the difference look bigger than it actually is. The Mori appears to be a significantly higher color temperature which means less light and the Phillips has the advantage of also having the Mori's light contributing to it's image.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    F8L, time to update the signature.
  5. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Doh! I'm slacking. :)
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    XS650 brings up a good point. Is there a reverse order picture available?
  7. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I have a feeling your better half just sits there and shakes her head with all that you've done to the car..
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    She does. This is nothing compared to my racing days. :D
  9. wick1ert
    1,311
    183
    Delawhere
    I've been told before that I'm never satisfied no matter what I do to my house/car/bikes/etc. I've got several items on my list of "wants" for them, but unless I win the lottery probably won't get them all done!
    Have you gotten the new kit for the HD back yet?
  10. weidake
    weidake Junior Member
    63
    Houston TX
    Color temp: Mori 5000K. Philips 4300K
    Reversed picture as requested
    Philips on top and Mori at the bottom. You can bearly see the Mori
    2 people like this.
  11. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Thanks!
  12. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I've gotten to the point that I am confident that I could perform this mod for others so if anyone is interested in upgrading their headlights but are afraid of a little baking then let me know and we can work out a method for your upgrade. I wouldn't charge nearly as much as the retrofit companies. ;)
    I would need to finish Matt's (Wickert1) motorcycle retrofit first though. That guy is one patient mofo. I just wish his bike was as easy as the Prius!
  13. Scotty Danger
    Scotty Danger Junior Member
    86
    Scottsdale
    I'll probably take you up on this at some point! Do you think that you would be able to insert LEDs into the existing spaces for the fake LEDs for DRL functionality? The Retrofit Source's LED kit would probably be way easier; I've checked out both install threads on Priuschat.
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    It is possible but you may need a small circuit board to handle all of the LEDs. I don't do that kind of work but my boys at the streo shop might or we could convince Darelldd to help since he just lives down the road and is a master with LED circuits!
  15. Scotty Danger
    86
    Scottsdale
    Haha OK cool good to know!
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Damm you guys...:D:D:D
    I've been working on my retro for some time now, but keep getting other things that pull me away. My retro includes:
    Euro Prius headlights, FX-R projectors, OEM D4 Denso Ballasts.
    This was the route I was going, but has since changed.
  17. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Your FX-Rs are going to spank our H1s! I soooo want them but I was scared I wouldn't get the rotation correct before sealing them up. I still have a set of the 2.0 s sitting in my backseat that I need to ship back.
    Keep us updated!
  18. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    Hey F8L, how do you adjust the height of the projector cutoff after its installed?
  19. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    You just use the oem adjustment screw. It's really simple and though most wrenches don't fit well in that location so I'd use a box wrench for the easiest access. I've been using a socket and twisting it with my hands but I've dropped it a few times and it's tough to find after that. lol
    The height of the cuttoff is easy to fit. The rotation of the projector, umm not so much unless you have the H1s or D2S. With the FX-Rs you are SOL once they are JB Welded into the housing.
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    That can be done with the headlight adjusters on the back of the headlight. If you find that you cant get it aimed right, you might need to re-position the projector in the housing.
