Headlight projector retrofit - HIDs to the max!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by F8L, Apr 29, 2011.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,986
    Fort Lee, NJ
    Sure, that will simplify things.
    Looking at the size of the Mini Gatling shroud, it may fit inside without trimming. I really hope so!
  2. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    There's never anyone here for packages. I always get stuck going to the USPS (there's only ever 1 person working and 10 people in line) or to the local UPS or FedEx if they require a signature. Then again, FedEx is great at leaving my packages at someone else's house. It's happened 3 times in the 5 years I've lived here. Someone once printed a Google map of my address and stuck it on the box for them to re-deliver. I laughed a bit at that! Luckily, they always managed to get every package and put it at my front door.
  3. Manksgloob
    Manksgloob Member
    243
    So to replace the HIDs in a 2006+ Gen II model, which projector type do you recommend?
  4. F8L
    19,011
    4,066
    50
    Grass Valley, CA.
    I think the DS2 would be the closest fit without having to cut. I would suggest calling Matt at TRS and see what he says. He knows the bulb base size for most bulbs and he could tell you if it is close to the D2S and D2R bulbs. If it is the same or smaller then then D2S projector will fit nicely. If you want to go all out then go with the FX-R projector but plan on some cutting. :)
  5. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    i less than three this thread. i could kiss you F8L, but you probably wouldn't want that
  6. F8L
    19,011
    4,066
    50
    Grass Valley, CA.
    Gross! LOL :D
  7. usbseawolf2000
    14,487
    2,986
    Fort Lee, NJ
    I have installed the projector and found the location (see last pic) I want to install the LED array. I have not put back the cover back on. I tucked both of them away in the closet so dust cannot get on (hopefully).
    It is a very clean install. I snaked out the high beam wire through the H4 bulb clip hole.
    I have a bunch of pictures. I will post more tomorrow.
  8. F8L
    19,011
    4,066
    50
    Grass Valley, CA.
    That looks great Dennis!
    One question though. The LED strip is a side emitting system. You have it mounted vertically with respect to the way the LEDs will shine. Is that your intent? I assume you powered them up and checked it out.
  9. F8L
    19,011
    4,066
    50
    Grass Valley, CA.
    Natalie McCarthy likes this.
  10. usbseawolf2000
    14,487
    2,986
    Fort Lee, NJ
    I have not power it up yet. Thanks for the tip! It would have been a major screw up!
  11. F8L
    19,011
    4,066
    50
    Grass Valley, CA.
    No worries brother. Power them up and mock place them where you think you want them then stand back a ways and check them out. They may work fine the way you have them. If not just lay them flat and see if the light emitted horizontally looks better.
  12. flareak
    1,016
    St Louis, MO
    Did you use the gatling shroud for those H1 minis?
  13. usbseawolf2000
    14,487
    2,986
    Fort Lee, NJ
    Yes, the pictures I posted are with the mini gatling shroud installed. It is small enough to fit inside the reflector without any cutting. It makes the install easy and best of all it comes with the projector.
    I used the H4 adapter plate (came with it) so I won't need to align or rotate the projector. Hopefully it is as super easy as it sounds. Let's see after I install the HID H1 bulb and light it up!
  14. usbseawolf2000
    14,487
    2,986
    Fort Lee, NJ
    A huge thank to F8L for walking me through this yesterday. I got more time to take these nice pictures.
    Remove the screws highlighted in Red. See below.
    Leave the ones highlighted in Green.
    Headlight in the Oven. 265 deg F preheat and 7 minutes baked.
    Headlight cover removed.
    Remove the halogen H4 bulb cover. The bolt is in the back.
    H4 bulb cover removed.
    Mini H1 projector - Prepare it to look like this with the silicone rubber installed. Remove the H1 holder and the projector locking ring first.
    Remove the high beam wires from the connector. Use a paper clip to push the two sides and it will slide through.
    Snake the wires through the hole highlighted. You can see the rear of the Mini H1 projector.
    Put the H4 adapter plate (comes with the projector) and screw the projector lock ring tight.
    Silicone rubber sandwiched between the projector and the reflector.
    3 people like this.
  15. F8L
    19,011
    4,066
    50
    Grass Valley, CA.
    Looks great Dennis. I knew this would be a breeze for you. Is the wife still upset about using the oven? :p
  16. usbseawolf2000
    14,487
    2,986
    Fort Lee, NJ
    She freaked out when I put the headlight in the oven. She stood there and gave me the "Wth" stare while I was on the phone with you. I had to calm her down. She was ok after 15 mins or so.
    To put the headlight back together, my oven is not big enough to fit both halfs. How did you do it?
  17. F8L
    19,011
    4,066
    50
    Grass Valley, CA.
    LMAO! As for the headlight. You actually want to put the lens on the best you can before putting it in the oven so it will be one piece instead of two. Then after baking it, you will simply press the lens into place and bend the clips back into place. Insert the screws that hold the lens ASAP.
  18. usbseawolf2000
    14,487
    2,986
    Fort Lee, NJ
    Made more progress today but there is a set back. One of the LED array is defective. This means I will not be able to complete the install this weekend since the replacement may not arrive.
    I am also unsure if the LED array and the wire may not survive 265 deg F in the oven when I close it back. I'll have to call TRS tomorrow.
    HID H1 bulb holder installed with 3 screws.
    H1 bulb installed with the clip holding it down.
    Testing how the LED would look. I think it looks awesome!
    The defective one.
  19. macmaster05
    macmaster05 Senor Member
    4,023
    712
    :( on the LEDs becasue your'e right, it looks AWESOME!
  20. F8L
    19,011
    4,066
    50
    Grass Valley, CA.
    Ohh man those looks good. I'm going to tear my headlights apart asap!
    What are you hooking the led wires up to?
Loading...
