Headlight projector retrofit - HIDs to the max!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by F8L, Apr 29, 2011.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I was thinking about hooking up the LEDs to the yellow parking light bulb plug. The LED array wire leads all the way to up that top right corner. There room there to snake it under the yellow plastic piece. This way, I'll have the option of having just the parking light on (one notch before headlight turning on).
    I don't have confidence with the reliability of it. I really don't want to open the headlights again to fix or remove it. If one or two LED dies in the array, it will bother me.
    I am leaning toward not putting the LED inside the headlight housing and finish up the project this weekend. It looks so good though!
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Ok cool. That is what I was thinking of doing as well.
    I'm going to somewhat hid my LEDs under the "ledge" above my projectors. That way if they fail at some point I can simply unplug them and not have to rebake the headlight.
    I think I'm going to try and get that done tonight.
  3. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Yea, that's true. It is hidden behind the fake LEDs for my headlight. If I don't power it, it will look just like stock.
    I just spoke to Matt. He gave me more confidence so I will put the LEDs in. This means, I will not be able to complete the install this weekend.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Just do it. :)
    Ohh and after watching this video I just want to cry. Those S2000 projectors are crazy insane bright compared to mine!
  5. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    S2000 projectors are very good for low beam. It doesn't have high beam so it is not applicable for us.
    Morimoto mini reserved some light for the high beam. I think it is a good compromise.
  6. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Cool!
    You know, while I had the headlight assembly taken apart, I would have taken out the orange reflectors to make it look like the euro style headlight. :)
  7. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Good suggestion. I thought about doing it too but I want to keep it there for three reasons:
    - I want to keep the stock look.
    - I don't want to violate any DOE headlight requirements to pass future inspections
    - It will help hide the LED power wire
  8. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Ok, some good news and some bad news. Good news first. LED lights look incredible.
    This is how it looks when both the projector with 4300k bulb and LED are powered up.
    Right in front, directly on the beam. LED is still visible.
    Here is a problem. The lower projector beam is hitting the reflector. I did not have that part of the reflector screwed in but it is seated. I'll have to screw it in and try again. I don't know if it is going to make a difference.
    The pattern of the beam resulting from it. Notice, the bottom of the beam getting blocked off and reflected to above.
  9. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Fantastic photos Dennis. Thanks. I can see what you're talking about (I could never take photos that well to convey exactly what I mean).
    I would think that screwing it in should fix your problem - the threads may angle the projector up just a tiny notch.
  10. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    This is with the headlight aimed all the way up. The halo rings are gone now but the level may be too high after I install it in the car.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I'd wait until you get it in the car before you start worrying. I had to raise my headlight level from the stock position so maybe you will too.
  12. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Does your Mini D2S projected light hit the bottom of the reflector?
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I nver noticed it while looking at the headlight but the projected beam does not appear to be affected by anything. I'll look again later today. :)
  14. Tideland Prius
    16,683
    lol.. I was just thinking how come no one did a projector retrofit and I come back and find out that you've not only thought about it, but actually did it! This idea came about when I saw that the European RAV4s had projector headlights (some had HIDs, some halogen projectors) while our RAV4s have multi-reflector headlamps.
  15. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I got the replacement LED strip. After speaking with him about it, he shipped it out within a hour (got email notification).
    I am waiting for my 5000k bulbs. I should get it by Wednesday or Thursday and I plan on finishing up by then.
  16. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    Hey, are you using the original ballasts F8L? If so, did you have to make a new notch in the OSRAM bulb to fit the D2R plug?
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I'm using the original factory ballast. There were no modifications needed to use the stock ballast. The factory connector fit right onto the Osram 66240 bulb.
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    My domain name expired yesterday. I renewed it and my pictures should be back up shortly. Grrr
  19. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Both headlights sealed for installation tomorrow. If everything goes well, expect some pics tomorrow night!
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I'm so jealous! They look great! Do the 2006+ headlights fit my 2005?
