Headlight projector retrofit - HIDs to the max!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by F8L, Apr 29, 2011.
  1. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    usbseawolf.....projector retrofit looks sooooo sick! like they were meant to be there!
    What do you want moneywise to do a set for me? :D
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    I will PM you. A second set should be quick since it is still fresh in my head.
  3. LIPriusFreak
    449
    34
    Long Island, NY
    I await you.....I'm local too :D
  4. CruZindon
    CruZindon New Member
    52
    Irvine
    When are these inspections done? I do not know if we have any in California except for smog checks.
  5. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I've never had to have my car inspected and I've been driving here for 20 years.
  6. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    In NY we need to have annual safety/emissions inspection. I beleive there are stricter standards for those of us in NYC but I'm not sure.
  7. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    It all varies now. New cars you can get registered for 5 years, and for so many years after that you can mail in renewal for up to 2 more years. Used cars, 2 years max.
    I'd have to go digging for the guidelines, but at somepoint they decided that vehicles made after a certain year didn't need to go through inspection. It's gotten pretty confusing to me, and I basically have to rely no the DE DMV to alert me of what I need done.
    Here's a link to the FAQ from the state website: State of Delaware Division of Motor Vehicles - Vehicle Inspection FAQs
    That's one reason I tend to only buy new, now. The prius isn't required to go in for any inspection at the end of the initial 5 years, but I can only renew for 2 years at that point. Registration is $40/yr for passenger vehicles.
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The great thing about a retrofit is it looks OEM and if you align your headlights properly then you shouldn't have any issues. Especially if your car came equipped with HIDs from the factory. Just don't use lame blue bulbs. lol
  9. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Shouldn't the LED's only be on for DRL? I guess that may require a switch and wire individually. A lot of extra work for daylight only. LED lights last forever, so I would not worry about one light burning out? Hal
  10. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Yea, I am not going to worry about turning the LED off when the projector turns on.
  11. babybird
    babybird Member
    117
    44
    Colorado
    In theory LEDs won't burn out since they have no filaments or failure-prone high voltage drivers to make them work. But in practice, they're still solid-state semiconductors, so they are subject to heat-related premature failure.
    That's not an issue for halogen or other incandescent bulbs where the heat is what causes them to produce light in the first place, and it's not an issue for HID lights where the light is produced by running high voltage through a gas to pump it up to the plasma state. But where halogen or HID bulbs can get up to several hundred degrees Fahrenheit, an LED has to be kept very cool-- preferably below 140 degrees F. Failing to design a properly heatsinked mounting for an LED light is certain to lead to premature failure.
    One thing that makes this especially difficult with an LED is that it produces its heat on the front of the diode where the light is produced, not on the back where it's easier to sink the heat away since it wouldn't block the light output.
    I've already seen some vehicles equipped with OEM LED headlight accents with burned out LEDs. Anecdotally, as a percentage of the whole, it seems to me that the failures are disproportionately on the few American models with LEDs vs. the German models, although I've seen more German models with them burned out purely because I see far, far more German models with LED lights. I don't think I've seen any failures on Asian models, but I don't know off-hand if any Asian vehicles actually come with LED DRL or other accent lights from the factory yet. All of the makes and models seem to have gotten the LED tail/brake lights and turn signals worked out just fine, but heat just isn't as much of an issue on the back of a car as it is up front with the engine etc.
    The other thing to consider is how they're wired, whether in series or parallel. Just like the old Christmas lights, depending on how they're wired up, one LED failure can either be just one LED burned out (Audi seems to do it this way), or result in the entire strip "failing" (I think this is what I've seen on the American models). Either way, I suspect that in nearly all cases, any failure would require replacing the entire strip to fix.
    The new Prius with full LED headlights may be an exception to the above, because those would present a safety issue rather than a cosmetic one, and the high output LEDs are likely mounted separately for reasons of heat dissipation.
    3 people like this.
  12. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
  13. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Nice read F8L. So true, factory fogs are useless. A bit confused though, if factory fogs are useless, then what's a person supposed to do? I wish he'd go into more detail about HID fogs. I'm assuming he stops short because he deems it unsafe or illegal. But if they can produce the light he goes on to describe I think it's a worthwhile discussion.
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    According to his article and what the guys on HIDPlanet.com promote, is getting a quality set of projector style foglights then use a good set of halogen bulbs. The problem with HIDs for fogs is their intensity. Mine work well as driving lights but the cast such a bright spot on the ground right in front of you that you may get too much glare in wet weather.
  15. Ryanpl
    780
    158
    Brooklyn, NY
    The next time I tackle a major mod project I've thought about swapping out my fogs for the projector style and replacing OEM bulbs with some good after markets. Good thing wife doesn't read PC :D
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Good thing most wives don't read PC. They may rate us out if they did. :)
  17. macmaster05
    4,050
    729
    Don't hold your breath, it doesn't take much to find someone online or create an account. But if I ever come across a post that says, "RYAN YOU'RE IN BIG TROUBLE!" I'll let you know...
  18. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I found a thread on HidPlanet that compares the Mini D2S to two other commonly used projectors. They put they the DS2 to shame but they would require some cutting to fit into our Prius housing. If you are good at fabrication work then I would suggest looking into these projectors or the FX-R. :)
    Here is a link to the thread. You my need to sign up to see the pics. If so please let me know and I'll ask Waylon to if I can post them directly here.
    Rx350 vs TL vs mini d2s
  19. weidake
    weidake Junior Member
    63
    Houston TX
  20. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    From an output standpoint I don't think you can beat the FX-R. It is an awesome projector with lots of color and you can use 50-55w HIDs without an issue.
    From an installation standpoint the D2S or H1 mini is a clear winner. The drawback is less output and you run the risk of melting shrouds or burning the bowl with the 50-55w ballasts.
    If I had the fabrication skill or was paying someone to do the work then I would go with the FX-R in a heartbeat!
    The output with my D2S minis is great and MUCH better than the factory HID setup but I do wish it was a bit brighter. I also wish I had used a 5000k bulb. The Osram bulbs I have still have a lot of yellow in them and although I am sure they are brighter than an aftermarket 5000k bulb, I still want the whiter look.
    I am going to have to purchase new headlight assemblies due to the inside lens being scratched. I'm contemplating doing an FX retrofit but I really don't want to dump much more money into this car since it's likely I may trade it in after some of these new hybrid/electric cars hit the market with better pricing. :)
