Headlight question.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Reaper, May 24, 2015.
  1. Reaper
    Reaper Junior Member
    61
    24
    Tampa, Florida
    I've checked the first 7 pages on this forum. I've also tried searching, but I really don't know what to type In The search bar. I have a little strip above the headlight that have little bulbs. They never come on. I've seen videos on YouTube from owners as well as videos from people just doing a video talking about the 2010 Prius and showing the features. Some of the videos they have this light stip that turns on. I can't get mine to turn on. I checked the fuses and none are blown out.
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    They're little nubs, they are purely cosmetic and don't light up.
    Hint: use Google search with priuschat.com as one of search parameters when trying to find things.
    Reaper likes this.
  3. fuzzy1
    10,167
    As already mentioned, on most Prii, including your's (my first Prius was a 2010-II), those are just nonfunctional decorations.
    Somewhere in here is a picture thread from someone who took the headlight assembly apart (requires baking), put in and wired up real LEDs, and successfully reassembled the whole thing. It was far more work than most of us are willing to put into it. If you want LED running lights or DRLs, it will be much easier and faster to get an aftermarket product that fits into the foglight plugs just below your turn signals.
    Reaper likes this.
  4. Reaper
    61
    24
    Tampa, Florida
    Thanks for the responses. I was thinking it might have been an option just for the Prius over seas.
  5. fuzzy1
    10,167
    They might be lit on some U.S.versions too, though without searching myself, I'm not certain. For your 2010 vintage, check first on the top trim level (V) and/or the ATP option. For later vintages, look first at the Plug-In Prius.
  6. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    Don't worry, I have the V with ATP, and they don't light up on mine either. They are purely decorative.
