Headlights – PiP base preformance……..
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 34Hupp, Oct 5, 2013.
  1. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    34Hupp, remember to avoid touching the bulb when handling them. The oils from your hands will create a hot spot on the bulb leading to premature failure.
    SCH-I535
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I fastened the ballasts to the plastic side panels on the fender on each side of the car.
    I used 3 self tapping stainless steel screws for each ballast. So now the ballast resides on the inside space between the fender and the plastic cover.
  3. mrbigh
    3,686
    699
    Long Island, NY
    Did you pull off the front bumper?
  4. cheung_francis
    cheung_francis Junior Member
    Can someone clarify where I can adjust the headlight aim on my base PIP?
    I apologize in advance if this was already discussed.
