Headlights burning out too often?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SidS1045, Sep 18, 2015.
  1. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    Mine is a 2011 Prius 2. I can change out both low beam bulbs in less than 10 min. I have never had a high beam to go out yet. I do not know why they would have to remove the front bumper. You just rotate bulb counterclockwise 45 degree or so and pull them out the back, The worst thing is getting the connector loose from the bulb before attempting the rotation, you have to squeeze it together. I just always use a pair of thin rubber gloves to keep finger prints off bulb so they say. Just reverse procedure for installing bulbs. No the bulbs are fixed in place, could have been a bad bulb or not installed right.
    #21 GaryD1, Oct 20, 2015
  2. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    I replaced my original headlamps when one burned out about a year ago I think. I bought the Sylvania H11 based on opinions and recommendations of those in this forum.
    Well, yesterday I drove home at dusk without any low beam headlamp lights. :(
    Guess I'll just get the cheaper, non HID bulbs this time and hope for a longer run on them.
  3. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I must be lucky. I still have the original bulbs in my 2010 with 55K miles and six years, three months on the clock. :p I was thinking of replacing them with a set of new bulbs but after reading this thread I'll keep them until one finally decides to burns out.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    @ALS, you do know that bulbs dim as they get older, right? ;)
