Headlights dim.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by SoShoreKen, Oct 20, 2021.
  1. SoShoreKen
    SoShoreKen Junior Member
    South Shore MA
    Last month or so my headlights are very dim. One side doesn't seem to even shine straight anymore. High beams and daytime running lights are fine. Just the low beams.
    I replaced the bulbs twice. Last time with brighter bulbs. But they look the same to me. Not brighter. I cleaned the headlight plastic too. No change.
    Anyone have any ideas?
  2. Air_Boss
    Air_Boss Senior Member
    4,262
    1,197
    New Yawk
    Any corrosion in the lamp socket or socket connection to 12V power leads?
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,989
    Texas Hill Country
    Assuming you are not getting cheap bulbs online, some of which are dim, I would suspect the sockets.
    While there are ways to check for unintended voltage drops, a good visual inspection of the sockets would be my first step.
    Tim Jones likes this.
  4. SoShoreKen
    South Shore MA
    What's the best way to clean the sockets? I'll check those when I can.
    Air_Boss likes this.
  5. rjparker
    11,152
    6,989
    Texas Hill Country
    If they are bad they will likely to be damaged. I would cut them out and splice in new sockets with a longer pre-terminated cable for ease of use.
    Another check would be the ground connections. A2 and A3. I would bet on a poor brand or damaged sockets first.
  6. Air_Boss
    4,262
    1,197
    New Yawk
    A fine brass brush or rotary 'pipe cleaner' is ideal to clean the socket electrical contacts, then apply dielectric grease. If they appear to be heat damaged, that is evidence of corrosion and resistance heating, and the socket is not serviceable. It could also be a cut through the 12V power leads. Squirrels and mice have been known to chew on Toyota (and Honda generator, ask me how I know) wire insulation, sometimes right through the conductors. You could use a DVM to measure voltage while wiggling the harness. If it is intermittent, follow the leads visually to inspect them for cuts.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Any kind of wire brush is not good because it can leave "splinters" inside the socket and cause a short.
    And recommending dielectric grease in places like that is not good either because most varieties of it is an insulator and may cause more problems than it solves.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    Some voltage measurements need to be taken.
    This could be a sign that there is a problem developing in the 12 V power system; battery, main connections or charging circuitry.
  9. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Are the bulbs LED?
    Are you sure the plugs are pushed in all of the way and click?
    #9 Tim Jones, Oct 20, 2021
  10. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It's possible that you have a poor ground connection at one of the headlights.
  11. Air_Boss
    4,262
    1,197
    New Yawk
    That's why you use a brass brush, and an air duster following the socket cleaning.
    Dielectric grease is specifically designed to seal without increasing resistance on properly mating surfaces.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    NO IT IS NOT.
    There are different kinds and some, the original formulas, are almost perfect INSULATORS.
    If you are going to put it on a conducting surface, you NEED to be sure and get the kind that IS conductive.......or else you are likely to be sorry.
