Headlights feel dangerous
Discussion in 'Gen 5 Prius Main Forum' started by cool_prius, Mar 11, 2025.
Tags:
  1. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Thank you for clarifying. I was convinced the L shape was causing the dark shadowed areas. I’ve never seen headlights that create shadows before.
    Gokhan likes this.
  2. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    Wow some articles say the new PHEV Corolla can get up to 1300 miles per tank. That's some serious MPG.
    Gokhan likes this.
  3. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    See the headlight map on the IIHS Prius page I linked above. It is required for all cars for the driver side to illuminate far shorter than the passenger side, as @Trollbait stated. So, Gen 5 Prius is no different in what you called a shadow. Nevertheless, as you see in the map, the headlight performance of Gen 5 is quite poor, as you also said.
  4. Gorgonzola
    Gorgonzola Member
    42
    28
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    Hi MVA - might you be willing to post a link to the YouTube video you referenced?
  5. Winston Smith
    Winston Smith Active Member
    473
    339
    OH
    2024 Prius
    LE AWD-e
    On yours, you'll use a phillips head screwdriver. Just use a flashlight and look down all the holes under the hood at each corner. You;ll see white metal teeth that are turned with the screwdriver.
    #25 Winston Smith, Mar 16, 2025
    Gorgonzola likes this.
  6. Trollbait
    12,822
    Pdog808 likes this.
  7. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Excuse me for asking, but what has tank size to do with MPG?
  8. Templeton
    Templeton Active Member
    371
    132
    usa
    2024 Prius Prime
    SE
    I looked on YouTube for videos on gen5 headlight adjustment, but could not find any. Could you post a link to the one you used? Thanks.
  9. scotched
    scotched Member
    Encino, CA
    2023 Prius
    I share you complaints. I've retrofitted HID projectors in past cars and I've noticed some of the downsides of our LED projectors.
    1. The physical cutoffs (where the end of the light meets the road) aren't smooth or straight. I think it's due to the shape of the actual LED module/board? It casts a silhouette that looks like it's being shined through tree branches. Worse than "squirrel finders" on old halogens.
    2. The cutoff color right at the edge of the beam is not a pretty blue tone like HID Projectors. It's 3-day old bruised arm yellow. When you point it at the side of the car it distorts the color of whatever you're looking at. Try it and you will never unsee it.
    3. Some of us can detect the pulsing of LED and it bothers our eyes. You noticed it when you drive your car at night when it rains and you can see it strobe. The light quality along with the harshness of the color bothers me.
  10. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    I wish they had brought the G4 Prime's headlights over to the G5!
    Gokhan likes this.
  11. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    they shouldve just done a hyundai like they did with the ioniq and had halogens for the LE prius that you can after market upgrade, or built in LEDs for the higher end models like the xle and limited
  12. Gokhan
    6,714
    2,661
    Paramount CA
    My Gen 4 Prius Prime Limited not only has quad LED headlamps but also fog lights. ;)
  13. Gokhan
    6,714
    2,661
    Paramount CA
    Here are the headlight maps for 5-lux minimum illuminance from IIHS. The short bars indicate the optimal distance for low (blue) and high (white) beams.
    Gen 4 Prius:
    Gen 4 Prius Prime:
    Gen 5 Prius:
    2025 Corolla:
  14. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    Should have been a bit more specific. The article states that the new PHEV Corolla (Prime?) can get 1300 miles on one tank plus a single charge. That number seems to be a significant increase over what a Prius Prime can get with one charge and a tank of gas (more like 600 miles or so in my personal experience.)
    So it would be logical to infer that the MPG on the Corolla (which has a 13.2 gallon tank vs.11.3 on my 2018 Prime) is significantly higher.
  15. Gokhan
    6,714
    2,661
    Paramount CA
    As if the range in miles isn’t mpg times the fuel-tank capacity in gallons, right?
  16. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    Yeah it was more of an off the cuff statement as doing math near midnight isn't one of may favorite pastimes :)
  17. Gokhan
    6,714
    2,661
    Paramount CA
    I wasn’t referring to you.
  18. daisy555
    1,729
    716
    CT
    That’s a great description. I described it as shadows but it does look like light is being shined through tree branches. What the heck were they thinking. Don’t they test these features before releasing them? They’ll probably fix it in 2026.
    Here’s a poor quality pic. They are simply not that bright.
  19. cool_prius
    cool_prius Member
    106
    38
    United States
    2025 Prius
    There's a whole business of people taking apart stock headlights and modding them. Usually to convert to projector lenses but also for style mods like painting the inside black. The Gen 5 headlights are very expensive right now but maybe in the future when used prices go down, someone might want to try to crack one open and improve the beam (and hopefully post to priuschat.com)
    daisy555 and scotched like this.
  20. scotched
    scotched Member
    Encino, CA
    2023 Prius
    @daisy555
    Before the Gen 5 Prius I had a 2015 Lexus CT with halogen projectors. THOSE lights were terrible in comparison to these. My retrofitted HID's + projectors on my other car blows the Prius away, but they run hot.
    I think "Jewel Eye" design (eg. Gen 4 Prius Prime) solves one of the LED drawbacks. Instead of having a single LED, you have multiple.
    daisy555 likes this.
