Headlights not showing wide field of view
Discussion in 'Gen 3 Prius Main Forum' started by Andrew19, Feb 10, 2022.
  1. Andrew19
    Andrew19 New Member
    Bay Area (California)
    Since I have started driving my 2010 Prius, I have noticed that it is very difficult to see at night, especially when turning. I just replaced the bulbs in the headlights but that didn’t seem to fix the issue. I believe the main problem is the field of view is so narrow, that it’s extremely hard to see to the side, so this makes turning (especially on sharp turns) hard to see because the headlights only see forward, not to the side. And there isn’t any fog lights to light up the side. I don’t know what to do. Maybe I have to just get use to it.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Probably.
    Any chance that you are developing cataracts ?
    That cuts down on night vision.
    So does aftermarket tint on the windows.
    With a 12 year old car, any indication that the headlight lenses are "yellowing" or are scuffed ?
    Reflectors losing some of their shine ?
    If that model has a "cutout" for fog lights, maybe some could be put in those spaces that would come on with the headlights all the time.
  3. AzusaPrius
    AzusaPrius Senior Member
    1,829
    811
    Could be a combination of things like what kind of bulb/wattage did you use or maybe the lenses are faded.
    You could also look on ebay for an aftermarket fog light kit.
    Easy to install and about $45-50 that is what I did.
  4. Andrew19
    Andrew19 New Member
    would this be the one you’re talking about? I want to make sure I get the right thing.
    For 2010-2011 Toyota Prius PAIR Fog Lights Bumper Lamps Wiring Switch Kit | eBay
  5. Noahdoge
    Noahdoge Active Member
    165
    119
    Mississippi
    Youtube “how to adjust headlights on prius” or look into the h9 conversion.
  6. fuzzy1
    10,159
    Are you comparing to other recent cars with better lights? When new, this model had quite reasonable lights for its era, and far better than what I was driving in the 20th Century. The bar on performance keeps rising, so it is behind the times now.
    Or does it seem to have some form of age or other degradation? A picture of the pattern against a wall at night might help reveal some problems.
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    The actual foglights in those kits are terrible though. They throw light everywhere and create glare that other people have to deal with.
    I used the wiring and foglight shrouds from a kit like that, then installed LED foglights that have better cutoffs to prevent glare. Something like these.
    PAIR CLEAR BRIGHT LED FOG LIGHTS FOR LEXUS TOYOTA 81210-48050 81220-48050 | eBay
