Headlights not working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Wing Man Lam, Feb 8, 2018.
  1. Wing Man Lam
    Wing Man Lam New Member
    San Francisco
    B5FE07DD-ECE2-4B97-89A9-1C1B1DB5AA84.jpeg 3396BA7F-C003-4539-9739-3E3CFDD88595.jpeg I have recently installed fog lights to the grille of my 2015 Prius 2, and everything has been working fine until last night. The headlights on both sides suddenly went off(I’m using HID’s), the side marker on one side is off, and after messing it for a while, both DRL’s will not turn on ejther no matter which setting I switch to. This morning the headlights and the side marker lights still wouldn’t turn on, but the DRL lights work again. Does anyone know why the headlights will not turn on anymore? I haven’t installed any resistors.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Where did you connect the HID ballasts to for power? If they were connected directly to the factory wiring harness, then you probably have a blown fuse.
  3. Wing Man Lam
    San Francisco
    I did connect them to factory. I was trying to check the fuses, but there’s no fuse for the headlights inserted in the slots of my fuse box indicated on the manual.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Fuses 20 29 And relay that triggers drls to off all are working properly?
  5. Wing Man Lam
    San Francisco
    There’s no 20,29 fuse installed in my fuse box. The DRL’s work now.
