Headlights on = dashboard off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by alanw, May 18, 2023.
  1. alanw
    alanw Junior Member
    missouri
    2005 Prius - Everything seems to be working fine, but as soon as I turn on the headlights, the dashboard lights go out - if I turn the headlights off, the dash lights return - Of course, I would like to have both working at the same time - any suggestions?
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    Have you already tried adjusting the dimmer dial?
    FYI : you're moderated until you've posted 5 times.
  3. alanw
    alanw Junior Member
    missouri
    I never thought to try that - i will tomorrow, thanks! And thanks for the welcome..
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    This^^^
    You have to turn the dimmer dial up to see the dashboard illumination with the headlights, or parking lights on during the day. When you reach the upper limit of dial rotation, you can keep applying pressure and it will "click" to Max brightness.
  5. alanw
    alanw Junior Member
    missouri
    I adjusted the panel dimmer light level and everything works fine again... thanks! My ego has taken a bit of a hit, but at least the car works as it should once again, lol...
    SFO and xliderider like this.
